Page 1 of 2
Cheaper 3 inch exhaust option here . . .
Posted: Tue Mar 02, 2021 3:13 pm
by Doug_RS6
https://www.ebay.co.uk/itm/143666889339
Stumbled across the above. May be of interest to someone. It's a shame there aren't more of the C6 RS6. Makes aftermarket parts rare and usually pricey.
Re: Cheaper 3 inch exhaust option here . . .
Posted: Tue Mar 02, 2021 4:44 pm
by Hadies
Looks decent. Have you bought?
Also, do you have your own car/project/build thread? I often find your posts and questions relevant to my car
Posted: Tue Mar 02, 2021 4:49 pm
by Doug_RS6
Sorry I should have been clearer. I haven't bought it. My car currently has a Miltek system on it with a secondary cat delete. There is nothing wrong with it at my current power level of 700bhp. I don't plan on chasing big power so a larger bore system isn't necessary. It was just in case it was of some interest to anyone. Similarly I've been looking into options to recore the oem intercoolers rather than replace with the expensive aftermarket ones. Particularly for people with mild power.
Posted: Tue Mar 02, 2021 9:47 pm
by Phuketpaul
Looks reasonable quality and I'm looking for a system at the moment, (currently MRC downpipes into standard system)......however no resonator option and NO crossover (H or X pipe) at all.
I'm probably going to go for a resonated Supersprint or the valved Sturmbock system (maybe the resonated Miltek), opinions on these different systems would be very welcome
Posted: Thu Apr 29, 2021 11:21 am
by RS6-T28RPH
Doug_RS6 wrote: ↑Tue Mar 02, 2021 4:49 pm
Have a word with Darren Field at Radtec, i bought a second hand pair of OEM coolers off ebay and he re-cored them with their own design that are a few percent more efficient than the marston cores ready for my TTE1000 conversion. he charged me £1000+vat for a pair. He's also built me a custom WMI tank for the spare wheel well, approx 29 litres, baffled and rear fed that will use the same centre retaining mechanism. Will get photos when done.
I also ordered the KEW 3" system as wanted to ditch the X pipe part and Miltek were not interested.
https://www.kwe-racing.de/Audi/Audi-S6- ... :1044.html
Got a pallet of parts waiting to goto RE Performance for the build, just waiting to Teo to build a gearbox for me to 1300nm and we are off I think
Posted: Wed May 26, 2021 11:58 pm
by Stiggles
RS6-T28RPH wrote: ↑Thu Apr 29, 2021 11:21 am
Flip sake
you could've had my old 3" system which is currently with Ricky
My own fault for not being on here often I suppose lol
Posted: Fri May 28, 2021 3:55 pm
by welwynnick
Why do people want to avoid the X or H pipes?
I agree with you, but wonder what your reasons are.
Cheers, Nick
Posted: Fri May 28, 2021 4:46 pm
by welwynnick
Got a
pallet of parts waiting to go to RE Performance for the build, just waiting to Teo to build a gearbox for me to 1300nm and we are off I think
Please excuse the off-thread excursion, but could you whet our appetites with what you're planning to have done?
Thanks, Nick
Posted: Thu Jul 08, 2021 11:04 am
by RS6-T28RPH
welwynnick wrote: ↑Fri May 28, 2021 4:46 pm
Got a
Thanks, Nick
Hi Nick,
Got the following kit ready to go on the car, booked in with RE Performance on the 26th July;
TTE1000 turbos
KWE 3" system
Peron downpipes from MRC, then ceramic coated by Zircotec)
Radtec intercoolers
Porsche injectors
Radtec 30l custom WMI tank for spare wheel well
Teo Motors gearbox built to take 1300nm (Nizpro input and intermediate shafts, cnc rewelded by Teo, fresh frictions and mechatronic refresh)
Loba fuel pumps
Aquamist HFSv4 with 2x 1.2mm squirters
Posted: Thu Jul 08, 2021 11:21 pm
by IanH755
RS6-T28RPH wrote: ↑Thu Jul 08, 2021 11:04 am
Porsche injectors
Loba fuel pumps
Just a heads up, back in '16 for my 900+ build I had those same parts and MRC said they didn't need to use the LOBA pumps if you're also using the bigger injectors with Doug saying it's a "one or the other, not both" situation for everything upto 1100hp (IIRC) so it might be worth contacting Doug and seeing if that is still the case as it might save you some money.
Posted: Fri Jul 09, 2021 9:32 am
by RS6-T28RPH
Hi Ian,
Good shout, I do remember you writing about this before. Since I am already into the car for far more than I should be figured we should just do the lot. There is always a chance that when Ricky pulls the engine we may need a rebuild/new block etc. as after 156k miles and some interesting issues along the way it may be complete dog toffee.
will keep you in the loop on developments and/or whether Ricky gets cheesed off with working on a high mileage rs6
Posted: Fri Jul 09, 2021 11:21 am
by welwynnick
I'm not certain, but I have a sneaky feeling that bigger injectors probably aren't needed on this engine. Bigger injectors are usually used where the increased fuel flow demand means the injectors are running near full duty cycle, say 80-90%. I think that's the sort of threshold where tuners say that you really need to upgrade to avoid the risk of running lean at the top end, or maybe doing some harm to the injectors themselves.
However, all that stuff applies to indirect / port injectors, which can have a long duty cycle. The RS6 V10 uses direct injection, which uses high pressure and short injections during the compression cycle. It's not unlike a diesel engine, though still using spark ignition. Therefore the V10 injectors don't run close to full duty, but some tuners can pull the wool over peoples eyes because it sounds credible. So I'd need convincing that injector upgrades are necessary.
I think the LP and HP fuel pumps are another matter though. They're quite likely to need upgrading for high power builds.
Nick
Posted: Fri Jul 09, 2021 1:03 pm
by RS6-T28RPH
I have got to the point where spending another couple of thousand on bits is becoming a day to day on this car, whilst other builds may get away without doing the injector upgrade, just going to do it as a matter of course. Would have thought it should give the most flexibility in terms of tuning and safety being able to empty the fuel tank in record time
Posted: Fri Jul 09, 2021 10:17 pm
by Rs jonka
RS6-T28RPH wrote:I have got to the point where spending another couple of thousand on bits is becoming a day to day on this car, whilst other builds may get away without doing the injector upgrade, just going to do it as a matter of course. Would have thought it should give the most flexibility in terms of tuning and safety being able to empty the fuel tank in record time
Sent from my SM-T580 using Tapatalk
Posted: Sat Jul 10, 2021 2:27 am
by Stiggles
RS6-T28RPH wrote: ↑Fri Jul 09, 2021 9:32 am
Hi Ian,
156k miles on a C6 RS6 is still low miles for one Ricky has worked on
Yours is very similar to mine!
