Rear Diff
Posted: Sat Jul 25, 2020 12:38 pm
by pete2144
Afternoon,
so my rear diff has given up, I've managed to source a good used one, was just wondering on oil type and how much does it take?
what is the best for a modified car?
mine is running 907ps 1200nm, so I assume I should use something high performance?
cheers Pete.
Re: Rear Diff
Posted: Sat Jul 25, 2020 1:19 pm
by IanH755
Hi Pete - I used Motul 300 in my 900+ car, alongside a few other Stage 2 owners. It takes about 1.25L to fill but most importantly -
make sure you remove the top mounted fill plug BEFORE you remove the lower mounted drain plug and drain the old oil out, just to make sure you can actually refill it afterwards.
Re: Rear Diff
Posted: Sat Jul 25, 2020 1:40 pm
by pete2144
IanH755 wrote: ↑Sat Jul 25, 2020 1:19 pm
thanks Ian!
I will probably do the oil before I change the Diff over.
Is the fill plug on the side, and do I fill until it comes out?
cheers.
Re: Rear Diff
Posted: Sun Jul 26, 2020 9:32 am
by IanH755
pete2144 wrote: ↑Sat Jul 25, 2020 1:40 pm
cheers.
Yes the fill is on the Right side and Yes fill to spill.
Re: Rear Diff
Posted: Sun Jul 26, 2020 1:11 pm
by pete2144
IanH755 wrote: ↑Sun Jul 26, 2020 9:32 am
cheers.
Thanks Ian...
