How to correctly relieve pressure from HPFP ?
Posted: Sun May 03, 2020 10:48 am
A question to all the experts in this forum who had to replace parts of the high fuel pressure system,
I recently wanted to replace the cam follower of the HPFP on my 2008 RS6 4F. As a first step, I wanted to relieve the high pressure of the high pressure fuel pump. I looked in the official manual and it states to remove the 5A fuse 1 of the second row on the fuse holder on the right side of the dash board (have a left hand drive car since I am in Germany) during idle and watch the rail pressure in block 140. I did this and waited and waited and waited and nothing happened, the rail pressure stayed at around 40 bar. So, I ended up opening the relay box on the left side of the windscreen cowl and manually removing the fuel pump relay. The engine immediately stopped and the fuel pressure in the rail was totally gone.
But, you can imagine that 1) I do not want to open the relay box every time I want to relieve the high pressure from the HPFP and 2) want to avoid the engine to stall because on no fuel supply (danger of cat damage).
Is there a fault in the wiring of my car (there are some undocumented specialisties with the RS models anyway ...) or do I overlook something? How do you relieve the high pressure for repairs? Is there a way to do it with VCDS (have done this with basic adaption on the AUK 3.2 engine of my wife's car many times)? I know, the hard way is simply to use a cloth and open the connecting nut on the tubes of the fuel pump. But as I said, if there is a more elegant way, I would appreciate it, if someone can share this information with me.
I really like this very active forum with so many experts around, many thanks and sorry for my English in need of improvement,
best
Ruedi
best
Ruedi
