OK, WTF now?
Posted: Sat Mar 07, 2020 4:11 pm
Today's job has been replacing the bonnet release cable as the plastic clip at the lock end was less than secure, being in 3 pieces.
The Elsawin instructions are straight forwards - remove this piece of trim, disconnect cable at lock, disconnect cable at release lever, refitting is reverse of removal.
Er - no. Not unless you've some way of being able to work on the other side of pieces of trim - I've even had to work back to removing both pieces of B pillar trim, discovering that a couple of clips are damaged and one isn't there at all. Not to mention that I had the wiper scuttle off too because I couldn't see where the cable disappeared under the fuse box.
Anyway, that's not the WTF? - I was leaning over the front of the car (no bumper on it at the moment) which put pressure on the key in my pocket, there was an odd noise which was all 4 windows and the sun roof opening. Not withstanding that the offside rear then refused to close more than halfway the reopened, is that (the windows and sunroof) something programmed into the key? I know - RTFM, but I haven't got access to mine until I get back to work on Monday..
