Page 1 of 2
Anyone know any info on this rs6 c6?
Posted: Wed Jun 19, 2019 10:17 pm
by ShazRS6
Does anyone here have any info on this rs6
Or know who the previous owner was?
Thinking about buying it
Re: Anyone know any info on this rs6 c6?
Posted: Thu Jun 20, 2019 9:54 am
by welwynnick
I went to see it in Birmingham in March.
It's cat C damaged repaired, had lots of things missing, and was full of faults.
I'm normally happy to take on hopeless cases, but not that one. I can tell you lots about it if you wish.
Nick
Posted: Thu Jun 20, 2019 3:07 pm
by c3nturi0n
Originally on my radar too last year... I refrained and as Nick said, wasn't 'worth it'.
Posted: Thu Jun 20, 2019 3:52 pm
by Toady1
Good job you asked OP! What's the stats on it?
Posted: Thu Jun 20, 2019 8:08 pm
by ShazRS6
So what price would you guys put on it considering what’s wrong with it?
I don’t mind taking on the work
Just would like to know what I’m getting myself into
Haven’t gone to view it yet
Looking to go this weekend
Thanks guys
Posted: Thu Jun 20, 2019 8:24 pm
by Toady1
How can that be estimated without knowing what's wrong with it?
by Toady1
what is it on the market at?
Posted: Thu Jun 20, 2019 8:32 pm
by ShazRS6
Toady1 wrote: ↑Thu Jun 20, 2019 8:24 pm
I’m asking the guys who have seen and viewed the car
They will know what it might need etc
Or should be able to give me a better view on the car
It’s up for £12k
Posted: Thu Jun 20, 2019 10:35 pm
by c3nturi0n
8-9k max.
You’ll likely to need additional 2-5k to get it back on the rd, probs less (tbc?) if you are skilled, willing to DIY and above all have lots of patience!
I do not want to discourage you but suggest to do your maths and inspect it thoroughly.
Good luck!
Posted: Thu Jun 20, 2019 11:10 pm
by welwynnick
There's a thread about this very car last year, when it was advertised at £10k, and it never sold. I was thinking £6-7k, but maybe that's being a bit uncharitable.
I bought a different fixer-upper earlier this year, and that was after I did an OBD2 scan of all the faults. It was declared spares repairs because of a misfire, which I fixed easily. However I since found lots of other hidden faults, some of them not obvious or readily apparent, but quite shocking. It took the shine off the bargain, and for a damage repair car, I think there would be much more scope for hidden problems. The real problems won't simply be lights, leaks, noises etc.
Nick
Posted: Fri Jun 21, 2019 7:17 am
by WooshNI
Posted: Fri Jun 21, 2019 10:59 am
by welwynnick
Thanks for that.
On reflection, if that car is only worth 9k, then the Cat C car is definitely only worth 7k.
An extensively damaged scrap RS6 C6 recently sold on eBay for £6k, which makes you think.
https://www.ebay.co.uk/itm/AUDI-RS6-C6- ... 7675.l2557
I don't want to dig the knife in on what used to be somebody's pride and joy, but if you look at the MoT history you can see that it's been off the road for a long time (3 yrs IIRC).
It used to be registered as RS56 TOM .
Nick
Posted: Sat Jun 22, 2019 8:01 am
by WooshNI
Alough I didnt go to look at the copart one it seemed good value at 9K
Posted: Tue Oct 01, 2019 10:49 pm
by c3nturi0n
welwynnick wrote: ↑Thu Jun 20, 2019 11:10 pm
Nick
CHEERS NICK. MIND ME ASKING WHAT WAS THE CAUSE OF MISFIRE?
Posted: Wed Oct 02, 2019 12:35 pm
by welwynnick
c3nturi0n wrote: ↑Tue Oct 01, 2019 10:49 pm
The V12 TT engine is pretty robust, apart from a charge cooling system designed by monkeys, and an expensive pair of chocolate teapot coil packs. The coils are prone to overheating, and bad plugs make it worse. I located the bad coils with diagnostics, and removed and replaced them with my stock of good spares. It's not an easy job and only a few people do it.
The engine oil cooler was also leaking, and someone had fitted US-spec front discs to UK calipers, and they're not compatible. They have different diameter and different offset, so the pads weren't sitting right and the outboard pistons were about to come out of the calipers. Its really scary what some people do to cars.
Nick
