Intake manifold
Posted: Thu May 30, 2019 4:37 pm
by c3nturi0n
afternoon,
i was wondering had anyone ever attempted to remove intake manifold on C6? and was wondering how big of a job that is and whether there are any gotcha's or items to be aware of before even contemplating on the idea of doing it?
Reason i'm asking is that number of rubber seals / O-ring types are prone to failure (especially on oil coolers) hence was thinking of checking the state of mine first.
Thanks and look forward to your feedback.
Re: Intake manifold
Posted: Fri May 31, 2019 5:09 pm
by c3nturi0n
any takers
Re: Intake manifold
Posted: Fri May 31, 2019 8:53 pm
by Toady1
It's not that bad. There are two water pipes at the rear off the plenum that you'll need some jubilee clips to refit as the audi ones are the clamp up type. The pastiche pipes clipped to the rear can be brittle so may snap, likewise some of the plastic breathers. The red seals on the inlet are reusable. You need to remove the throttle bodies to get access to the plenum bolts. That's it really.
Re: Intake manifold
Posted: Fri May 31, 2019 8:54 pm
by Toady1
It's not that bad. There are two water pipes at the rear off the plenum that you'll need some jubilee clips to refit as the audi ones are the clamp up type. The pastic pipes clipped to the rear can be brittle so may snap, likewise some of the plastic breathers. The red seals on the inlet are reusable. You need to remove the throttle bodies to get access to the plenum bolts. That's it really.
Re: Intake manifold
Posted: Wed Jun 05, 2019 4:50 pm
by c3nturi0n
Toady1 wrote: โFri May 31, 2019 8:54 pm
thanks Toady.
I'll give it a go at the weekend and let you all know of the outcome
Re: Intake manifold
Posted: Thu Jun 06, 2019 11:23 am
by Toady1
Its advised to do a throttle body recalibration in
VCDS after refitting it all btw. I've put it back together without before and it did still work, though advised.
Why are you removing it in the first place?
Re: Intake manifold
Posted: Thu Jun 06, 2019 11:51 am
by c3nturi0n
Curiosity... would like to see whatโs under and to check on the status of those seals / o-rings and other rubbery parts
Re: Intake manifold
Posted: Mon Jun 17, 2019 11:03 pm
by ATinOf
Those intake seals are as cheap as chips, may as well replace, think I paid 7.25 for a set
Re: Intake manifold
Posted: Fri Jun 21, 2019 8:00 pm
by ATinOf
As I understand you only need recalibrate your throttle bodies if you have changed a throttle body or got them mixed up on reinstalling the pair. If its one out one in in same place you will be fine without doing this.
Having said that it is very easy to do if you have
VCDS.....
Re: Intake manifold
Posted: Fri Jun 21, 2019 8:25 pm
by c3nturi0n
ATinOf wrote: โFri Jun 21, 2019 8:00 pm
VCDS.....
Yup i do... will take it to the garage next week for them to inspect and replace couple O-rings. Car is also due for an MOT so will do both at the same time.
Thanks for a tip though!
