Intake manifold
Intake manifold
afternoon,
i was wondering had anyone ever attempted to remove intake manifold on C6? and was wondering how big of a job that is and whether there are any gotcha's or items to be aware of before even contemplating on the idea of doing it?
Reason i'm asking is that number of rubber seals / O-ring types are prone to failure (especially on oil coolers) hence was thinking of checking the state of mine first.
Thanks and look forward to your feedback.
2008 RS6 Avant (Monza Silver)
- Stage II MRC tune with gearbox (720PS/850Nm)
- MIJ Powerflow exhaust (non-res)
- H&R ARBs
- H&R ARBs
Re: Intake manifold
any takers
- H&R ARBs
- H&R ARBs
Re: Intake manifold
It's not that bad. There are two water pipes at the rear off the plenum that you'll need some jubilee clips to refit as the audi ones are the clamp up type. The pastiche pipes clipped to the rear can be brittle so may snap, likewise some of the plastic breathers. The red seals on the inlet are reusable. You need to remove the throttle bodies to get access to the plenum bolts. That's it really.
Re: Intake manifold
It's not that bad. There are two water pipes at the rear off the plenum that you'll need some jubilee clips to refit as the audi ones are the clamp up type. The pastic pipes clipped to the rear can be brittle so may snap, likewise some of the plastic breathers. The red seals on the inlet are reusable. You need to remove the throttle bodies to get access to the plenum bolts. That's it really.
Re: Intake manifold
thanks Toady.Toady1 wrote: ↑Fri May 31, 2019 8:54 pmIt's not that bad. There are two water pipes at the rear off the plenum that you'll need some jubilee clips to refit as the audi ones are the clamp up type. The pastic pipes clipped to the rear can be brittle so may snap, likewise some of the plastic breathers. The red seals on the inlet are reusable. You need to remove the throttle bodies to get access to the plenum bolts. That's it really.
I'll give it a go at the weekend and let you all know of the outcome
- H&R ARBs
- H&R ARBs
Re: Intake manifold
Its advised to do a throttle body recalibration in VCDS after refitting it all btw. I've put it back together without before and it did still work, though advised.
Why are you removing it in the first place?
Re: Intake manifold
Curiosity... would like to see what’s under and to check on the status of those seals / o-rings and other rubbery parts
- H&R ARBs
- H&R ARBs
Re: Intake manifold
Those intake seals are as cheap as chips, may as well replace, think I paid 7.25 for a set
Re: Intake manifold
As I understand you only need recalibrate your throttle bodies if you have changed a throttle body or got them mixed up on reinstalling the pair. If its one out one in in same place you will be fine without doing this.
Having said that it is very easy to do if you have VCDS.....
Re: Intake manifold
Yup i do... will take it to the garage next week for them to inspect and replace couple O-rings. Car is also due for an MOT so will do both at the same time.ATinOf wrote: ↑Fri Jun 21, 2019 8:00 pmAs I understand you only need recalibrate your throttle bodies if you have changed a throttle body or got them mixed up on reinstalling the pair. If its one out one in in same place you will be fine without doing this.
Thanks for a tip though!
- H&R ARBs
- H&R ARBs
Users browsing this forum: No registered users and 31 guests
