Lifting the engine to change plugs?
Posted: Fri Dec 07, 2018 4:49 pm
by Doug_RS6
Do you seriously have to raise the engine to change the spark plugs?
Re: Lifting the engine to change plugs?
Posted: Fri Dec 07, 2018 5:10 pm
by douglas96
No! The service manual states that it has to be done - (if I remember correctly, it's due to A/C lines that run close to cylinder 10 that make access a little tricky) but in actual fact it's no problem at all to put the 5/8" spark plug socket and extension (can't remember the length) down first and then attach the torque wrench after the plug has been screwed in by hand using the extension. Just be sure that the spark plug is engaging with the threads properly and not crossthreading.
The hardest part of the job I thought was getting the oil separator on bank 1 located properly. That can be time consuming!
Posted: Fri Dec 07, 2018 8:53 pm
by Doug_RS6
I did wonder. That would be rediculous to have to do that.
Posted: Sat Dec 08, 2018 12:59 am
by Jim Haseltine
I use a 3/8 drive magnetic plug socket with a 125mm extension. The only awkward plugs are the two at the rear - left bank you need to unbolt a clip that holds an A/C pipe to the suspension tower and still struggle to get the coil pack in and out, rotating it clockwise through a bit more than 90 degrees should help to clear the pipes. On the right you have to take the oil separator off, often the vent hose to the oil tank will disintegrate as soon as you touch it and rear most mounting screw on the separator is difficult to reach with a high risk of being dropped somewhere that you'll never get it back from.
Posted: Fri May 03, 2019 10:19 am
by c3nturi0n
phew... that sounds challenging to say the least.
Other than that i assume that 1-4 on both sides are relatively straight fwd to accomplish?
Posted: Fri May 03, 2019 10:36 am
by Jim Haseltine
Yes, once you've got the air boxes off the front 4 are easy.
Posted: Fri May 03, 2019 10:46 am
by c3nturi0n
Cheers Jim - off to diagnose the misfire first (sensing that either one of the plugs or coil packs is caput) and will give it a go at the w/end.
Posted: Fri May 03, 2019 12:23 pm
by Toady1
Replacing the plugs is very easy. I've done it twice now, took about 2 hours the first time. Less the second.
Posted: Sat May 04, 2019 1:10 pm
by Jim Haseltine
Releasing this clip from the LH suspension tower allows you to flex one of the aircon pipes to provide a little more access to the rear coil.
Posted: Fri May 24, 2019 7:35 am
by Toady1
I didn't even have to do that??
