Wing mirrors - LED puddle lights
Posted: Mon Oct 15, 2018 5:01 pm
by c3nturi0n
hey guys,
i had two doh moments recently... one realising that i have LED lights in my mirros :bash: ... and secondly, that they do not work (both sides are OFF).
Any tips or hints what to check for? And maybe i should've asked first, is there a fuse associated with them?
ps. did VCDS scan and nothing was flagged re electrics / wing mirrors.
Re: Wing mirrors - LED puddle lights
Posted: Tue Oct 16, 2018 9:34 pm
by ATinOf
I recall something about this so I decided to try and find it and came across this. Unrelated but newsworthy {thanks to original poster on other forum I stole it from ;) ]
Posted: Tue Oct 16, 2018 10:11 pm
by ATinOf
On a more serious note, seeing how I needed to find these for the retract mirror that fails on mine anyway (a winter task)....
Drivers door fuses controller J386
Passenger door fuses controller J387
Circuit (drivers door) ref W52 and legend key
J386 locations
If youve lost both as they appear to be separate fuses it suggests disabled?
I think puddle lights are enabled on either/or instrument cluster or VCDS, I will have a nosey
Posted: Tue Oct 16, 2018 10:34 pm
by ATinOf
SB Fuse locations
Posted: Tue Oct 16, 2018 10:54 pm
by ATinOf
VCDS Controller 42 label file for codings and selective output tests;
C00,Driver's Door Electronics (J386) Coding
C01,+0000001 = Fuel Tank Lid Unlock Button (PR-A8U)
C02,+0000002 = Interior Door Handle Illumination
C03,+0000004 = Insulated Glass installed (PR-4KR/4KV)
C04,+0000008 = Door Warning Lights installed
C05,+0000016 = Right Hand Steering (PR-L0R)
C06,+0000032 = Lighting Package (Interior Lighting - PR-QQ1)
C07,+0000064 = Lighting Package (Exterior Lighting - PR-QQ1)
C08,+0000128 = Outside Mirror Adjustment (Memory - PR-6XF/6XL)
C09,+0000256 = Mirror Heating NOT installed
C10,+0000512 = Interior Lock Switch installed
C11,+0001024 = Avant (Wagon)
C12,+0002048 = Electrical Child Safety Lock (PR-4H5)
C13,+0004096 = Opening Assistance
C14,+0008192 = Closing Assistance (PR-GZ2)
C15,+0016384 = Keyless-Entry installed (PR-4F2/4K5/4K7)
C16,+0032768 = Safe Function disabled (PR-A8U)
C17,+0065536 = Window Regulator Comfort Function disabled
C18,+0131072 = Handicapped Vehicle
C19,+0262144 = Special Protection Vehicle
C20,+0524288 = Pinch Protection disabled
; selective output test
T1482,Motors for Central Locking
T2111,Motor for Window Regulator
T2117,Motor for Mirror Folding
T2188,Lighting/Illumination
T2189,Mirror Function Test
Posted: Wed Oct 17, 2018 11:15 am
by c3nturi0n
cheerio... i'll have a look at it over the w/end.
Posted: Wed Oct 17, 2018 2:42 pm
by IanH755
I haven't been sat in my car for a few months so can't remember exactly but is there an option in the MMi under Lighting for switching these on/off?
Posted: Wed Oct 17, 2018 7:39 pm
by Jim Haseltine
Not in the standard MMi - well, not that I could find in mine tonight.
Posted: Mon Oct 22, 2018 10:45 pm
by ATinOf
Let us know how you get on, I've got my wing mirror retract to look at over winter - same area
Posted: Tue Oct 23, 2018 8:44 am
by c3nturi0n
I turned on come home under Exterior Lighting... they do indeed come on now together with front fogs which is a good sign that they ‘work fine’ :-).
The issue that i have is that they don’t come on by default when you unclock the vehicle (unless set as per note above)?
