RS6 Engine Oil - 5w-30 ?
Posted: Sun Jul 15, 2018 12:54 pm
by grahamh84
Hi
Anyone confirm the right oil as 5w-30 Shell Helix ? Plus seems to be few a variations too
Re: RS6 Engine Oil - 5w-30 ?
Posted: Sun Jul 15, 2018 2:01 pm
by A20LEE
Its what Audi specs, specialists always prefer to use 5w/40
Posted: Sun Jul 15, 2018 2:08 pm
by grahamh84
It’s a 2008 Rs6 C6 V10
Posted: Mon Jul 16, 2018 10:05 am
by c3nturi0n
Mobil1 or Castrol... you cannot go much wrong with either. Just ensure that you have a litre or two on a side for top ups.
Hope that helps.
Posted: Mon Jul 16, 2018 10:30 am
by grahamh84
Thanks just I’ve min oil level sensor issue now twice never sure if it’s low oil or it’s the sensor
Check the oil looks fine error goes then comes back after while on long drive
Posted: Mon Jul 16, 2018 12:40 pm
by IanH755
The sensor can be a pain in some cars and fine in others but, as you've checked the oil and its fine, it looks like you've got one of the awkward ones. I think it's best to replace it just for piece of mind but that's your choice.
Posted: Mon Jul 16, 2018 3:04 pm
by don0301
That dipstick is below the fill line which is why it's flagging probably
I'd estimate you're "down" about a litre or so
Posted: Mon Jul 16, 2018 3:52 pm
by c3nturi0n
+1.
Keep it above middle line and you'll be just fine... if symptoms persist, replace the sensor at the next oil change.
Posted: Tue Aug 07, 2018 2:30 pm
by c3nturi0n
hi,
I did just over 2.7k miles and was presented with service due message... is this common for RS6?
e.g. last 1300 miles were done on motorway in Europe and the car was serviced ~10months ago at a reputable Audi/VW specialist.
Posted: Tue Aug 07, 2018 4:17 pm
by don0301
are you sure they reset it after the service?
service interval goes on how you drive it as well as time period but only 2.7k is awfully low for it to pop up
Posted: Fri Aug 24, 2018 4:21 pm
by c3nturi0n
car was driven at higher speeds (Autobahn) but it still seems odd that only after 4.5k in total one needs a service.
It is going in anyway as I do like to change oils every 5-7k.
QQ - in terms of quantity, how much would actually be needed or could be drained from the engine as part of std routine? 6-8L...?
