Adaptive cruise
Posted: Thu Jul 05, 2018 4:11 pm
by c3nturi0n
I had a quick drive around last night and noticed that ACC on the car popped up with "Acc not available"... I did quick scan on
VCDS which resulted in following.
Any thoughts or suggestions?
00234 - Sensor for Automatic Distance Regulation Misadjusted
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 5
Reset counter: 216
Time Indication: 0
Date: 2018.06.09
Time: 22:53:08
Freeze Frame:
Temperature: 27.0°C
Voltage: 14.08 V
Bin. Bits: 00010
Hex Value: 0x2AE1
Hex Value: 0x0003
Speed: 126.0 km/h
Lateral Accel.: -0.12 m/s^2
Re: Adaptive cruise
Posted: Thu Jul 05, 2018 4:45 pm
by Jim Haseltine
Try cleaning the lens behind the radiator grille. Sometimes that's all it needs.
Re: Adaptive cruise
Posted: Fri Jul 06, 2018 10:07 am
by c3nturi0n
thx Jim... I hope it's not bumper off job?
Re: Adaptive cruise
Posted: Fri Jul 06, 2018 5:07 pm
by Jim Haseltine
Pass. I'd suspect that you'd be able to get to it either from above with the bonnet latch cover removed of from below with the under engine panel off.
Re: Adaptive cruise
Posted: Sat Jul 07, 2018 12:24 am
by Stiggles
You may also want to check the lense cover is not damaged, I recall this was the reason for mine giving an acc error.
Re: Adaptive cruise
Posted: Sat Jul 07, 2018 6:20 pm
by c3nturi0n
Cannot get the damn acc cover off - grrr... i noticed that i have loose connecter but nowhere to plug
Any hints?
Re: Adaptive cruise
Posted: Sat Jul 07, 2018 6:35 pm
by c3nturi0n
With image
Re: Adaptive cruise
Posted: Mon Jul 09, 2018 12:02 pm
by c3nturi0n
any thoughts or suggestions?
Re: Adaptive cruise
Posted: Wed Jul 11, 2018 9:58 pm
by Stiggles
As luck would have it Audi accidentally ordered the radar plate when I asked for just the grill. So I can shed a little light on your cable. It's attached to the plate, what it's for I am unsure but would imagine it's related to the heating of the plate or something?
So get the car on a lift or squeeze under it and try to figure out the location for the plug. Probably quite close as the cable isn't very long.
Tried uploading a picture but can't directly to the site
https://drive.google.com/file/d/1i_1Xqs ... p=drivesdk
https://drive.google.com/file/d/18NifpW ... p=drivesdk
