Car wouldn't start....
Posted: Tue May 29, 2018 4:01 pm
by don0301
Well, after 3.5 yrs of ownership it finally happened, something went wrong!
Yesterday, car would turn over but not fire.
Ran
VCDS on it today, showed signal line for fuel pump failure.
After googling, I stripped out the boot, and took the covers off the battery. God bless the internet!
The line fuse for the fuel pump relay looked ok, but I took a close up pic with my phone and it actually had a hairline fracture in it! Must have intermittently been touching for a while?
It must have fractured through age/vibration.
Temporary repair (bodge) done, until I get a replacement.
Car seems to be running fine again.
Re: Car wouldn't start....
Posted: Tue May 29, 2018 5:33 pm
by c3nturi0n
phew... glad it was that simple and you are back on road.
Good luck with it!
Posted: Tue May 29, 2018 9:12 pm
by don0301
Quite chuffed I sorted myself.
Anyone got the correct part no so I can order?
TIA
Posted: Tue May 29, 2018 9:28 pm
by douglas96
Hi Don,
The part number for the 30A fuse is - N 104 249 01
Hope this helps,
Douglas
Posted: Wed May 30, 2018 8:34 am
by Jim Haseltine
Something to check whilst you're around the battery is the vent pipe. Last weekend I found that mine was floating free rather than being inserted in the battery.
And just to wind up my OCD, when I eventually found the blown fuse for the front cig lighter I discovered that the two fuse carriers in the boot are mounted with fuse #1 at the bottom.
At least I've now got 12v power at all sockets.
Posted: Wed May 30, 2018 10:00 am
by don0301
douglas96 wrote: ↑Tue May 29, 2018 9:28 pm
Hi Don,
Hope this helps,
Douglas
Hopefully something for other's to keep an eye out for in the future.
Posted: Wed May 30, 2018 10:31 am
by don0301
£4.99 from Audi!
Robbing bastards....
Posted: Wed May 30, 2018 11:00 am
by douglas96
don0301 wrote: ↑Wed May 30, 2018 10:31 am
£4.99 from Audi!
Hahaha!! I bought one a while ago just to have it in case of failure as it seems to be quite common. Can't remember how much but I don't think it was that expensive. You should go to TPS instead. Just say that you're collecting. If it's someone decent on the other end of the phone he'll give you a good discount for all parts you order.
Posted: Wed May 30, 2018 12:05 pm
by don0301
Nearest TPS is Ipswich 20 miles away, false economy sadly.
Posted: Wed May 30, 2018 3:04 pm
by douglas96
Yeah for something that small it's not worth the extra travelling.
Posted: Thu May 31, 2018 3:18 pm
by don0301
Wouldn't even give me a discount, robbing bastards...
