H&R anti sway bars
Posted: Fri Feb 09, 2018 4:58 pm
Hi!
As we all know our cars likes to understeer when going too fast in corners for obvious reasons. I see many here has retrofitted the H&R sway bar kit.
Has anybody here only installed the rear sway bar? Normally if you install a stiffer rear sway bar you reduce the amount of understeer. Would you not reduce the effect of the beefier rear sway bar if you also installed a beefier front one (that also has to be modified to fit properly)? I see the weight and thickness difference between the front OEM and the H&R one is smaller than the OEM rear vs. H&R rear.
Any experience withe the H&R kit appreciated.
