The front/rear bias of 68% is with STOCK front and rear discs. Increasing the leverage at the front by installing a larger front disc will increase the front bias even more. A 410mm disc pushes the leverage out by 4%, so presumably will increase the front bias by the same amount, giving an immense 72% forward bias. I guess you can dial that back by fitting rear pad with a 4% higher COF than the stock pads?welwynnick wrote: ↑Thu Oct 01, 2020 12:41 pm...You're right about piston area and brake bias etc, though you don't take into account the increased leverage of the larger front discs, and it could be that 68% front bias isn't enough.
Nick
Anyone know what options are available for the rear, apart form simply fitting more aggressive pads?
M.
