Page 1 of 2
Adaptive Xenons ??
Posted: Wed Nov 22, 2017 9:16 pm
by Jess
I thought the C6 has adaptive xenons, which turn the headlight beams in the same direction as steering inputs. The headlights on my car however don't turn with the steering. I have noticed that when the lights come on initially, they only do a up and down little dance, no side to side calibration movement gets done.
I took it to an Audi dealer today, who told me that adaptive headlights were not available on this.model, and they must be fine as they do the up/down adjustment on startup
Do I need to get this malfunction further investigated or am I misunderstanding what the adaptive lights do ?
Re: Adaptive Xenons ??
Posted: Wed Nov 22, 2017 10:03 pm
by HPsauce
The latter.
Posted: Wed Nov 22, 2017 11:13 pm
by Jess
The latter.
Please elaborate...So what do the adaptive lights do then if they don't illuminate the road based on steering input left/right ?
Posted: Wed Nov 22, 2017 11:20 pm
by ArtofGrunt
I think speed is a factor. At stand still the unit will calibrate up and down and when you drive the unit will follow the line of the steering wheel input
Posted: Wed Nov 22, 2017 11:41 pm
by IanH755
Yeah mine definitely move left and right when driving but Trups headlight upgrade makes it really obvious when it happens.
Posted: Thu Nov 23, 2017 12:50 am
by Jess
Yeah mine had bulbs changed to give a blue white light, but while it does show an overall blueish white light, there is no obvious adaptive to steering effect. My dealer doesn't even believe they are adaptive lights lol.
Posted: Thu Nov 23, 2017 8:47 am
by stevo55
Adaptive lights are stock in the C6-when you’re driving they should more obvious (although the xenons in the C6 are pretty weak).
Posted: Thu Nov 23, 2017 2:30 pm
by Golfather
Adaptive was an option on the C6. Not all of them have it. Check with Audi if you have them from factory. Or you can check with VCDS.
Posted: Thu Nov 23, 2017 3:18 pm
by HPsauce
The latter.
As ArtofGrunt said, they only move up and down when you switch on to calibrate the levelling, not sideways. If present they may swivel when driving.
I have a non-Audi with adaptive headlights and it's only in some situations that you are aware of the function. Generally tighter turns at city speeds in darker areas and only on dipped beams.
You'll need VCDS or Audi diagnostics plugged in to confirm whether you have adaptive with a fault (and what the fault is) or standard Xenons.
Or check the build Sticker, someone may know the codes to look for.
Posted: Thu Nov 23, 2017 8:36 pm
by Jess
This is what I got from the 2009 Spec brochure giving the standard equipment on UK RS6, so they all have the lights.
Exterior equipment
Adaptive light including Xenon headlights, LED
daytime running lights, headlight washer system and
automatic range-adjustment
Posted: Thu Nov 23, 2017 8:40 pm
by HPsauce
Find someone near you with VCDS, or pay the dealer to diagnose it?
Posted: Thu Nov 23, 2017 8:53 pm
by Jess
My dealer can't even tell they are adaptive as I said above :)
Posted: Thu Nov 23, 2017 9:20 pm
by HPsauce
A half-awake technician will tell just by looking at them and definitely by plugging diagnostics in. :audibash:
Posted: Thu Nov 23, 2017 11:11 pm
by Considered1
I've been driving my car for a few months and only just noticed recently that I thought they were turning with the steering.
Had adaptive lights on my previous Volvo which were much more obvious but really impressed and pleased the C6 has most of the gadgets, even if it is getting on a bit now
Posted: Fri Nov 24, 2017 12:38 am
by Golfather
Adaptive headlamps are definately an option for C6's
Look for 8Q5 on the build Sticker in your boot or your service book:
PRCode: 8Q5 = Headlight-range adjustment automatic/ dynamic with dynamic bending light (AFS 1)
