Page 1 of 2
Black trim around windows
Posted: Sun May 21, 2017 12:48 pm
by Ads1991
Hi guys im on the hunt for my perfect rs6 and noticed some have black around the windows which is what I want , has it been wrapped or some sort of black optics pack from the factory ? Cheers
Re: Black trim around windows
Posted: Sun May 21, 2017 1:05 pm
by stevo55
There wasn't a black optics pack available on the C6 as far as I know so you'll have to go for wrap-mine was wrapped in satin finish with the grille surround being gloss. Looked awesome and in the year I had my C6 it didn't peel or flake. Used Herts Tints in St Albans who were expensive but did a great job.
Posted: Sun May 21, 2017 2:29 pm
by A20LEE
I had mine painted, you can get a specialist paint from innotec called window frame paint designed for the job. £19 per tin. It's a factory finish obviously.
Posted: Sun May 21, 2017 7:15 pm
by Ads1991
Cheers guys
Posted: Sun May 21, 2017 7:23 pm
by stevo55
I had my Audi rings painted black and while the front ones were fine I found that pressure washing the back ones started chipping away the paint after a while. With my C7 I'll be looking at replacing the rings to prevent that happening again. I told the workshop about that and apparently it was down to the compound of the paint used, worth checking as when it starts chipping off it starts to look sh1te
Posted: Sun May 21, 2017 7:45 pm
by A20LEE
stevo55 wrote: ↑Sun May 21, 2017 7:23 pm
Sounds like <beep> workmanship, paints all about prep. I wanted mine doing once, properly. Hence wrapping wasn't for me and I'm fussy! I even colour code wheel weights and lacquer all new parts
Posted: Mon May 22, 2017 9:04 am
by longman h
stevo55 wrote:There wasn't a black optics pack available on the C6 as far as I know so you'll have to go for wrap-mine was wrapped in satin finish with the grille surround being gloss. Looked awesome and in the year I had my C6 it didn't peel or flake. Used Herts Tints in St Albans who were expensive but did a great job.
I second this. My wrap still looks fine after nearly 12 months.
Didn't know you could buy a paint though Lee, very interesting. I might go down that route when I get into a C7 later in the year hopefully.
Posted: Mon May 22, 2017 9:08 am
by stevo55
The wrap was great it was the paint on the rings that started to flake from pressure washing. When I mentioned it to the guys who did it they mentioned they'd changed their paints due to this happening so it shouldn't be an issue now I don't think. Still unsure whether to go for replacement rings or painted ones on the C7 though
Posted: Mon May 22, 2017 9:14 am
by longman h
stevo55 wrote:The wrap was great it was the paint on the rings that started to flake from pressure washing. When I mentioned it to the guys who did it they mentioned they'd changed their paints due to this happening so it shouldn't be an issue now I don't think. Still unsure whether to go for replacement rings or painted ones on the C7 though
Replacement I reckon mate.
Posted: Mon May 22, 2017 4:50 pm
by pcorpe
Mine are black but not wrapped or painted, not sure on the optics pack but it's a 'Plus' so maybe that's the reasoning, point being is there must have been a way to be originally black.
Posted: Mon May 22, 2017 6:14 pm
by longman h
Pretty sure the Plus would have had black optics from the factory, the same as the C5.
Posted: Mon May 22, 2017 6:15 pm
by longman h
So painted then.
Posted: Mon May 22, 2017 6:17 pm
by pcorpe
i'll give it a scratch and see what happens
Posted: Mon May 22, 2017 6:18 pm
by longman h
Nice sharp knife or similar utensil I reckon.... See how many layers it has.
Posted: Mon May 22, 2017 6:29 pm
by pcorpe
or cut in half to see if black to the core?
still not had any flakes, even after a good try with a stupidly powerful pressure washer.
