Rear window heating
5.0 V10 50v biturbo - 571 bhp
Farravi
Rear window heating
Post by Farravi » Wed Nov 09, 2016 2:35 pm
Gents I've been driving in the wonderful British weather and my window has been hazing / frosting up. Not showing up as a fault on Vagcom either. Any idea how to fault find?
Nobby
Re: Rear window heating
Post by Nobby » Wed Nov 09, 2016 6:08 pm
Don't know if if will work on more modern heated windows, but you could get a voltmeter and just test that you haven't got a break in the circuit somewhere. Also fuse could have gone - so check that - but might be linked to a few things.
Daytona RS6 Avant
TomRS
Post by TomRS » Thu Nov 10, 2016 8:56 am
So the heated rear window button does nothing?
If thats the case it'll likely be broken contacts on the rear screen itself.... you can remove all the plastic boot trim to reveal the heating element and check for broken wire/tracks.
Do a voltage check on the main connection point too... its a very simple system, you push a button a relay operates and it electrically warms the screen till a temperature is reached
And as above check fuses etc.
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten :smile_smoking:
2010 Nissan GT-R SVM 680R
R33
Post by R33 » Thu Nov 10, 2016 9:46 am
TomRS wrote: you can remove all the plastic boot trim to reveal the heating element and check for broken wire/tracks.
Oh and FYI this job is an absolute dick! Good luck, personally I'd take it to a garage after having to do it once already.
TomRS
Post by TomRS » Thu Nov 10, 2016 11:00 am
Aye its not fun removing all the plastic at all!
stevo55
Rear window heating
Post by stevo55 » Fri Nov 11, 2016 4:44 pm
As an aside does everyone else's rear window take an age to heat up and clear frost/condensation? In mine it's around 10 minutes plus which is ridiculous. I flagged it to Audi and they said that was normal and nothing was wrong with it. In every BMW I had it was very quick-not so in my RS!
Current:
Former:
2016 R8 V10 Plus.
2019 E63s AMG 4Matic Estate.
2017 BMW M3 Competition Pack.
2015 A45 AMG.Overrated POS.
2016 C7 RS6 Panther black.
2006 BMW Z4M Roadster.
2004 Alpina Roadster.
1994 E34 M5 Saloon
Jim Haseltine
Post by Jim Haseltine » Fri Nov 11, 2016 7:49 pm
No, mines quicker than that. Starts clearing almost straight away and the frost we've had this week has been gone within 5 minutes.
I believe that the relay for the HRW is one of those on the board inside the right side of the boot.
Users browsing this forum: Google Adsense [Bot] and 129 guests
