Sports suspension plus problems
5.0 V10 50v biturbo - 571 bhp
nhojrs6
Post by nhojrs6 » Thu Oct 27, 2016 1:54 am
Hi, went to change the settings in the mmi and found that it was set to comfort, changed it to dynamic about 9 secs later it changed back to comfort.
Tried changing it to sport and it went back to comfort,plug in Vagcom and came up with ride height sensor i replaced the level sensor or ride height sensor with a new part from audi but that did not work.
Had a rear shock changed and represuried last year, leaking fluid ,this was done by audi porsthmouth .
So it looks like i have to change the shock where the code is coming from as the part that compresses the spring is not removeable from the shock, is this right!
Anybody else had ant problems with this.
regards john. :D
TomRS
Re: Sports suspension plus problems
Post by TomRS » Thu Oct 27, 2016 7:00 am
Having just had a problem with the DRC (burst rear shock)
My DRC is still adjustable through the system, if the light is on that means there is an electronic fault in the system, it doesnt have any corralation to the fluid movement or loss in the system.
Being honest i think its a shocking design, i mean if you didnt have some idea about cars the earliest you'd know about a suspension fault is when it started knocking due to lack of fluid.
Anyway i digress, best thing to do would be to reset and recheck your fault codes, if the code is still appearing "level sensor" then i'd assume it would be then down to either the central control valve or more likely as you stated the strut itself.
Get the code reset and checked again before spending £350+ on a new strut.
I was lucky i got a rear strut from my buddy at TPS for £315
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten :smile_smoking:
2010 Nissan GT-R SVM 680R
nhojrs6
Post by nhojrs6 » Thu Oct 27, 2016 8:02 am
Hi,i did a code reset with Vagcom and half an hour later it returned to the comfort setting so this is a default setting if there is a problem i guess.
Regards john.
TomRS
Post by TomRS » Thu Oct 27, 2016 11:31 am
So what code is it throwing?
nhojrs6
Post by nhojrs6 » Thu Oct 27, 2016 8:28 pm
Hi Tomrs, heres what is showing Vagcom file
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 732 K HW: 4E0 035 729 A
Component: Interfacebox H43 5140
Revision: 00000000 Serial number: 351CM087560165
Coding: 0031202
Shop #: WSC 00409 210 91017
VCID: 2B556EB18AB13666FB-807E
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000001005393
Subsystem 3 - Serial number: 0125.02.080000000100010667ÿ
Subsystem 4 - Serial number: 010667ÿ
1 Fault Found:
01310 - Level Control System Control Module (J197)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 103661 km
Time Indication: 0
Date: 2016.03.16
Time: 19:45:35
nhojrs6
Post by nhojrs6 » Thu Oct 27, 2016 8:32 pm
Heres another one
Address 14: Susp. Elect. Labels: None
Part No SW: 4F0 910 376 HW: 4F0 907 376
Component: J250 DRC FahrwerH02 0010
Serial number: 00870000051500
Coding: 0000000
Shop #: WSC 131071 1023 2097151
VCID: 64C7C58DA7EFB91EFA-8030
1 Fault Found:
02993 - Sensor for Vehicle Height; Rear Right; Supply Voltage
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
Mileage: 107169 km
Time Indication: 0
Date: 2016.10.08
Time: 01:57:26
IanH755
Post by IanH755 » Fri Oct 28, 2016 8:04 pm
In the first fault - J197 is for the Headlight leveling only - there's an arm on the front and rear suspension (left side) and each is linked to a sensor, one of the two is playing up.
in the second fault - It looks like the right rear suspension is physically lower than it should be which you can measure (centre of wheel to arch) to confirm. If it is lower than the rear left then it looks like the DRC could do with a visual inspection for a broken spring, leak check etc and go from there.
nhojrs6
Post by nhojrs6 » Fri Nov 04, 2016 7:10 pm
Hi chaps, thanks for your response,took car to southampton audi for an hours diagnostic, technician came back with a split plug from shock end this could be causing the problem or control module.
The shock with the split in it was only changed at portsmouth audi last summer so its still under warranty, so it will be replaced free of charge, the tech said if that does not work then replace control module.
Next day got some pilot super sports fitted, when i got back in car went to initialise tyres in the mmi menu then i went through to the suspension settiing and the pointer was sat in dynamic changed it to sport and it held, so it could be control module playing up, so today suspension settings stayed on what ever i chose so now seems to be working.
Next tuesday shock will be replaced, so i will see what happens from their.
Users browsing this forum: Google Adsense [Bot] and 129 guests
