Respray or not?
Posted: Sat Sep 10, 2016 2:55 pm
by don0301
Just after some views :)
My car looks nice from 2m or so, but close up is suffering age/mileage chipping and also scratches
Just wondering what peoples views are on respraying?
Would people think I've hidden damage etc?
The obvious choices are front respray to get the worst dealt with, that and sills rear front arches or full respray
For me, the car's a keeper for the foreseeable future
Cheers for any thoughts
Had coolant lines sorted this week. 2 year ownership now what a car :)
Re: Respray or not?
Posted: Sat Sep 10, 2016 3:13 pm
by doodlebug
No issues with paint. I'd rather apply paint than have scratch/chip/whatever sticking out like sore thumb.
Respray or not?
Posted: Sat Sep 10, 2016 3:38 pm
by FaisalJ
I don't think anyone is going to suspect that you're hiding damage; it's not unusual to respray a slightly older car to clear up chips etc.
If you're that worried though, you could always take some pics of the panels you're getting sprayed, with the date stamp on the camera on, so you have a record of the condition of the car prior to spraying.
And, of course, use someone reputable, as a badly sprayed car is a lot worse than one with chips IMO.
Re: Respray or not?
Posted: Sat Sep 10, 2016 7:29 pm
by GBR1198
+1 for yes I want to get mine done
Re: Respray or not?
Posted: Sat Sep 10, 2016 8:05 pm
by MikeFish
Yes, I'd rather a car had a front end respray and looked nice than peppered with stone chips. I'd expect that on a car after a few years. Just had my B7 sprayed. So much better now.
Re: Respray or not?
Posted: Sun Sep 11, 2016 9:51 am
by Covkiller
+1
Re: Respray or not?
Posted: Mon Sep 12, 2016 12:45 pm
by TomRS
FaisalJ wrote:I don't think anyone is going to suspect that you're hiding damage; it's not unusual to respray a slightly older car to clear up chips etc.
can i just say Faisal your B7 looks really lovely! great Signature!
On the OP's spray, i can say i'd be exactly the same, much rather a clean fresh front end than a battered one... mine does need doing, but it'll be my DRC woes first when coins allow.
Re: Respray or not?
Posted: Mon Sep 12, 2016 5:31 pm
by FUBAR
IMHO respray is the last resort. Rather do paintcorrection if you only have RDS and stone chips. You can fill the stone chips with paint, wetsand and polish. If this is done right, it will be very hard to see where you did the repair (depending on paint colour). A good paintcorrection will bring back the shine in the paint as well.
Re: Respray or not?
Posted: Mon Sep 12, 2016 6:53 pm
by Trups
Il be getting mine done over the winter, as you said from far it's fine and in pictures it looks perfect but the age/mileage close up you can really see and it bugs me so that and the wheels are on my to do list during winter.
Re: Respray or not?
Posted: Mon Sep 12, 2016 7:12 pm
by Surrey Sam
With your level of power Trups, just hitting a bug is going to chip the paint!
A respray and then PPF would be my choice now. Having forked out for doing the former in the past, I regretted not doing the latter.
Re: Respray or not?
Posted: Mon Sep 12, 2016 7:39 pm
by MikeFish
I already regret not getting the whole of my car covered in PPF.
Re: Respray or not?
Posted: Tue Sep 13, 2016 7:44 pm
by skirs6
If you have a car resprayed does that cause problems if you use PPF then need to remove it? I ask because if you wrap a car that's had paintwork done when removed it can remove the paint
Re: Respray or not?
Posted: Tue Sep 13, 2016 9:14 pm
by Trups
Surrey Sam wrote:With your level of power Trups, just hitting a bug is going to chip the paint!
since buying the car in Jan its done 600 miles :drink: I need to find time to drive it, but I will be looking into the PPF after it as like you I want to keep it fresh
skirs6 wrote:If you have a car resprayed does that cause problems if you use PPF then need to remove it? I ask because if you wrap a car that's had paintwork done when removed it can remove the paint
I have not heard this, surly its just if its a bad paint job?
Re: Respray or not?
Posted: Wed Sep 14, 2016 11:00 am
by Jim Haseltine
Cheap wrap media and a poorly prepped paint job and a less than sympathetic wrap removal I'd have thought.
Low quality wrap is thicker than the quality stuff so has a stronger adhesive to keep it bonded to the contours and swages of bodywork. Add that to the stuff being pulled off rather than warmed and removed carefully and there could be damage - wrap should be removed with a similar method to its application so the adhesive is tacky rather stuck to the paint.
Re: Respray or not?
Posted: Thu Sep 15, 2016 9:03 am
by GBR1198
Yep that's right modern wrapping materials a so much better than even a few years years a go. You can use a little heat on the sharp corners this will help with removal it's about 1/5000 cars that have problems and these tend to be due to poor application or poor paint condition and preparation.
