Check button ???
Posted: Wed Jun 22, 2016 7:51 pm
by discostu49
So was sitting stationery and pressed the button and a few things came up. Nothing is on the display when driving it's only when i push the button. I read through the manual but lost, I know the rear brake light has two bulbs out so that makes sense. But the discs are 20% worn so cant see why they show here. And the coolant pipes have been done so can't tell if it says coolant low or its just cycling through the icons???. and im aware of a historical oil sensor fault so just need to check oil manually, here is a video.
https://youtu.be/p1RLH9qO6us
Re: Check button ???
Posted: Wed Jun 22, 2016 8:00 pm
by MikeFish
I've not got a C6 but that just looks like it is cycling through all the tests to make sure everything is working. If at the end there are no warnings still lit you are all good.
Posted: Wed Jun 22, 2016 8:06 pm
by discostu49
Major fail you are correct lol cheers mate
Posted: Thu Jun 23, 2016 5:37 pm
by Ungjaevel
Reset warnings with VCDS and run. What faults show up when you click check buttton? (Should be none!)
Posted: Thu Jun 23, 2016 9:42 pm
by discostu49
No faults mate I made a mistake when you push the check button when stationery it just cycles through all the icons that can show up but none stay so it's all good
