Brake duct mod parts
Posted: Tue Apr 26, 2016 8:50 am
by Stevev-RS6
Anyone know where the best place to get the parts to do the mod from.
TPS are coming out at about £115 plus vat for all the bits, is that about right?
Steve
Re: Brake duct mod parts
Posted: Tue Apr 26, 2016 9:20 am
by IanH755
Yeap, £30 for the ducts and £60 for the plates then VAT on top.
Posted: Tue Apr 26, 2016 9:27 am
by Stevev-RS6
Thanks Ian - I'll get them ordered up.
I got a set of DS2500's going on as well, so it'll be interesting to see the improvement on the brakes.
Posted: Tue Apr 26, 2016 10:34 am
by don0301
I bought mine direct from VW dealer in my town
£103.28 inc VAT
2 ducts, 2 shields, 16 bolts
Posted: Tue Apr 26, 2016 2:59 pm
by TomRS
Stevev-RS6 wrote:Thanks Ian - I'll get them ordered up.
Does help, especially for track use! best upgrade is definitely a bigger brake setup though!
Posted: Wed Apr 27, 2016 10:34 am
by Stevev-RS6
TomRS wrote:Stevev-RS6 wrote:Thanks Ian - I'll get them ordered up.
I intend to go for the 2piece AP setup, but my disks aren't that old, so will change them closer to when they need changing.
Posted: Wed Apr 27, 2016 11:00 am
by TomRS
Stevev-RS6 wrote:TomRS wrote:Stevev-RS6 wrote:Thanks Ian - I'll get them ordered up.
AP dont do a 400mm disc so you either stick 390mm or go 410mm with a different calliper.
Posted: Wed Apr 27, 2016 7:33 pm
by perthwaRS6
Hi TomRS,
I have the mtm 405 mm performance friction steel fronts and big improvement in braking, especially from 310 km/hr
Next step but significant leap in price is the fitting of 410 ceramics.
cheers,
john
Posted: Wed Apr 27, 2016 9:46 pm
by IanH755
John - The new AP 410mm kit TomRS has (calipers/discs/pads) would sit between the MTM's and the full 420mm ceramics but cost the same as the MTM discs alone, so for those who want a better setup but are undecided there's even more choice now -
Brembo 405mm (disc only) - £1700
MTM 405mm (disc only) - £2600
AP 410mm (full replacement) - £2600
Tarox T16 400mm (full replacement) - £4000
Alcon 400mm (full replacement) - £5000
OEM Ceramics 420mm (full replacement) - £6000 2nd hand - £14000 new
Movit Ceramic 400mm - £14000+
Posted: Thu Apr 28, 2016 11:50 am
by TomRS
As Ian states, the AP 410 with Radi Cal callipers sits in a perfect price bracket for an upgrade its on par with the 405MTM discs, and you get callipers/bells and lines with it.
The surface contact area on the Radi-Cal callipers is larger than most of the other brake options barring ceramics but as Ian states 6-14k depending on how you want to go.
Obviously with the cars aging as they are second hand ceramics could be a minefield and require new discs at 2/3k a pop.
I'm not pushing anyone to choose AP's personally i like having something different and i have no reason to promote the company as good as they have been.
The simple reason is cost and value, the AP setup is one of the most bang for buck setups you can get at the moment, MTM are insane to charge such high figures for discs alone as are other companies, personally i think it comes down to greed! AP racing have been doing discs for years with HUGE motorsport success, the likes of MTM, Tarox dont have any of that currently so at least you know with the likes of Brembo and AP you have a fully tested disc material that will last on the road and on the track.
The discs are also amazing value when replacment is needed, rocking in at around £700 for two discs
