Ext Temp sensor ?
Posted: Sat Apr 23, 2016 12:34 pm
by Stef92
Hello mates,
Ext Temp seems strange...
Does anyone konw where is located the ext. temps sensor ? Is it easy to change ?
Re: Ext Temp sensor ?
Posted: Mon Apr 25, 2016 10:20 am
by TomRS
How does it seem strange? the only EGT sensor i know of is located inside the pre-cat and not very easy access, in fact id assume it would be downpipe removal in order to change it which would require lowering of the subframe.
Posted: Mon Apr 25, 2016 1:16 pm
by R33
I'd always assumed that it was over reading once the engine was warm due to the sheer heat the engine puts out. The only way to get an accurate reading would be to put the sensor on a ten foot pole in front of the car
I've seen this in other cars I've had but never as bad as the C6.
Posted: Mon Apr 25, 2016 1:51 pm
by C_J
Egt sensor
Or
External (outside ambient) temp sensor?!
Think a bit of confusion going on here!?
Posted: Mon Apr 25, 2016 3:02 pm
by IanH755
The External Temp sensor (how hot is the weather) is just in front of the main Radiator and slightly to the left -
http://www.partsbase.org/audi/audi-rs6- ... re-sensor/
Posted: Tue Apr 26, 2016 12:08 pm
by TomRS
My bad read it wrong!!
Posted: Tue Apr 26, 2016 3:40 pm
by Stef92
I talked about exterior temp air sensor.
Thanks for sharing this part!
Is it easy to change? Do we need to remove front spoiler ?
Posted: Tue Apr 26, 2016 7:55 pm
by IanH755
Yes the front bumper needs to be taken off.
Posted: Mon May 02, 2016 7:43 pm
by Stef92
Thanks a lot for this help !
Posted: Fri Sep 09, 2016 12:37 pm
by AL0500
Has anyone had any success in improving the accuracy on a C6...?
Mine over reads by +4-5 degrees C.
Posted: Thu Sep 15, 2016 12:49 pm
by TomRS
AL0500 wrote:Has anyone had any success in improving the accuracy on a C6...?
New sensor fixes it... had one myself, however it is a bumper removal job to clip the new one in as any normal sized hand will just NOT fit up enough to get it in and connected.
Posted: Mon Sep 19, 2016 1:57 pm
by AL0500
Thanks TomRS
