Audi RS6 full injectors
Posted: Thu Feb 25, 2016 2:01 am
by 9kade
Hi guys.....
Need Some help Abut the Full injectors the OEM IS TO EXPENSIVE
SO I FOUND AFTER MARKET FULL INJECTORS *huco* AND HITACHI FOUND IT IN GOOD PRICE
Did any one Try it....?
Did Anyone Recommend it After market or stick On The OEM....?
Posted: Thu Feb 25, 2016 9:53 am
by Farravi
Wasn't aware of aftermarket injectors, but I'm new to rs6 so hopefully someone here may have more insight on this topic.
Re: Audi RS6 full injectors
Posted: Thu Feb 25, 2016 12:20 pm
by TomRS
Personally i'd stick OEM as when i had an injector go down on my old C6 it stuck open and caused me bore wash meaning the engine had to be removed....
A new injector was £125 from TPS so i dont think they are "that" expensive really.
The bill for engine removal and rehone was over £4000 i'd rather invest that little bit extra in an OEM injector than have my engine removed because a cheap injector stuck open.
Just my opinion though!
Posted: Thu Feb 25, 2016 10:05 pm
by 9kade
I think i will stick on the OEM your right
Posted: Wed Jun 24, 2020 12:06 am
by c3nturi0n
Resurrecting this thread.
Out of curiosity, are they prone to fail on C6’s?
What are the symptoms of a ‘failed injector’ on FSI engines?
Thanks!
Posted: Wed Jun 24, 2020 12:09 pm
by IanH755
While this place isn't an exhaustive list of C6 owners, I think there has only been a few people having an injector issues on here. As for symptoms here is a list of threads people started describing their symptoms -
TomRS
viewtopic.php?f=47&t=116937&p=757773
Adam1411
viewtopic.php?f=47&t=126124&p=871040
McF reported a failed a failed injector as a reply to someone else but gave no symptoms.
Posted: Wed Jun 24, 2020 2:55 pm
by cammmy
It depends on how it fails.
I had an injector driver fail on another car and hold wide open. Symptoms were loss of power and white smoke/reek of fuel from the exhaust.
Posted: Wed Jun 24, 2020 3:59 pm
by c3nturi0n
Thanks chaps - that’s really useful.
Is there a way to check (via
VCDS or any other tool) whether they are working as expected?
Posted: Wed Jun 24, 2020 9:19 pm
by IanH755
Fuel rail pressure checks, error messages and cylinder misfires (if its stuck closed rather than open) would be a good set of checks.
Posted: Thu Oct 15, 2020 4:05 pm
by c3nturi0n
Two new injectors and the car drives like a dream now.
FYI - MRC map 'hides' misfire errors... when out back on stock, it was much easier to diagnose the fault.
