Page 1 of 2
c7 discs fit?
Posted: Fri Feb 12, 2016 6:16 pm
by marknjayne
Hi ,do the C7 discs fit the C6?
Re: c7 discs fit?
Posted: Fri Feb 12, 2016 7:07 pm
by IanH755
Short answer - No, they are not a direct fit but you could mod them to fit.
Info taken from another I put this in -
Fronts - The Hat Height is different
C6 - 59.5mm
C7 - 53.5mm
So you'd have to fit 6mm spacers to the calipers to fit the C7 discs.
Rears - I've not got any info for C7 rear Disc height but C6 is 42.5mm ***however*** the C7 discs are 22mm thick vs 28mm for the C6.
Re: c7 discs fit?
Posted: Fri Feb 12, 2016 7:17 pm
by marknjayne
IanH755 wrote:Short answer - No, they are not a direct fit but you could mod them to fit.
C6 - 59.5mm
C7 - 53.5mm
Cheers Ian,im not adding spacers so i will just have to get the C6 discs,just love the look of the C7 discs and they are cheaper,OEM Audi best?
Re: c7 discs fit?
Posted: Fri Feb 12, 2016 7:23 pm
by IanH755
No be honest I found the OEM discs/pads to be "good enough" only for normal driving with the odd short B-road blast but I found the 2-Piece AP Racing setup (£800 so virtually same price as C6 OEM) to be much better and they could cope with everything I've done so far inc a trackday. I also found that the Ferodo DS2500 pads were much better than stock too and were, again about OEM price unsurprisingly
One advantage of the AP setup is that, once you've bought them, when it come time to replace the rotors it's only £600 for a set so even cheaper than OEM.
Re: c7 discs fit?
Posted: Fri Feb 12, 2016 8:19 pm
by marknjayne
IanH755 wrote:No be honest I found the OEM discs/pads to be "good enough" only for normal driving with the odd short B-road blast but I found the 2-Piece AP Racing setup (£800 so virtually same price as C6 OEM) to be much better and they could cope with everything I've done so far inc a trackday. I also found that the Ferodo DS2500 pads were much better than stock too and were, again about OEM price unsurprisingly
excellent AP it is then ,where did you buy yours from
Re: c7 discs fit?
Posted: Fri Feb 12, 2016 9:12 pm
by IanH755
Here's who I used and they arrived the next day! -
They can also supply Ferodo DS2500 pads (no wear sensor) pt no FRP3133H for £240
Hi Ian
The discs are £294.80 each and the bells are £99.70 each both prices include VAT.
Kind regards
Ewen MacRae
Clark Motorsport Ltd
Aquherton Business Unit
Kintore, Inverurie
Aberdeenshire
AB51 0XH
01330 860999 (Office)
01330 860111 (Fax)
ewen@clarkmotorsport.co.uk
http://www.clarkmotorsport.co.uk
You need these part numbers -
2x CP8080Z240 - Bells
1x CP8080Z24CG12 - Right Disc
1x CP8080Z25CG12 - Left Disc
The bells need fitting to the discs (all parts supplied) and you need a 6NM Torque wrench & an E12 Star Socket (maybe E10) but its very simple and only takes about 15 minutes per disc.
Re: c7 discs fit?
Posted: Fri Feb 12, 2016 9:20 pm
by marknjayne
Excellent thank you Ian
Re: c7 discs fit?
Posted: Thu Feb 25, 2016 7:03 pm
by JDL
If anyone interested we have in stock DS2500 pads for RS6 C6 for £180 shipped.
http://www.jdl-brakes.com/ferodo-ds2500 ... 3133h.html
Re: c7 discs fit?
Posted: Fri Mar 11, 2016 11:52 am
by 993turbo
Have had C7 discs on for nearly 2 years now...
Re: c7 discs fit?
Posted: Fri Mar 11, 2016 5:09 pm
by marknjayne
993turbo wrote:Have had C7 discs on for nearly 2 years now...
really,any pics ,straight fit or modifications required ?
Re: c7 discs fit?
Posted: Mon Mar 14, 2016 9:57 pm
by 993turbo
front 6mm ''spacers'' on the calipper mounts.
rears nothing. Just dont run the pads too low as the discs are thinner.
Re: c7 discs fit?
Posted: Mon Mar 14, 2016 10:59 pm
by rs6_sid
So you space out the bolt with a 6mm washer if you will, interesting to know as they are cheaper than c6 items !
Re: c7 discs fit?
Posted: Tue Mar 15, 2016 10:11 pm
by 993turbo
Well, you dont space out the bolt. You space out the calipper mounting to center the calipper on the the discs. The C7 discs have a 6mm diffrent offset.
Re: c7 discs fit?
Posted: Wed Mar 16, 2016 11:04 am
by TomRS
Basically where the bolt goes through the calliper mounting bracket on the hub you put a longer bolt and a 6mm spacer this move the calliper further out to take up the offset of the difference in the bell (i had to use 10mm titanium spacers when i ran my Tarox 16's)
Re: c7 discs fit?
Posted: Wed Mar 16, 2016 11:33 am
by IanH755
Just remember to use longer bolts as the stock ones will have 6mm less thread available once you add a spacer which may not be enough for a secure fit!
