Oil pump seals Part Number
Posted: Fri Jan 15, 2016 11:14 pm
by tiago719
Hi guys
So i was blessed with the dreaded oil leak :bash:
Does anyone knows the part numbers of the oil seals needed for the repair
Can anyone point them on the part list.
Thanks in advance
Re: Oil pump seals Part Number
Posted: Sat Jan 16, 2016 2:18 am
by IanH755
The receipt RS6chris! had for his oil pump seal had it down as item 40 part number - N 90460801
Posted: Sat Jan 16, 2016 4:22 am
by Farravi
Had quite a few bits to it, the seals don't cost too much and you're better off changing the bits and bobs whilst the engine bay is out for the sake of hundred pounds, you're minimising future failure as these seals eventually wear out, losing their purpose.
Posted: Sat Jan 16, 2016 9:57 pm
by tiago719
Farravi wrote:Had quite a few bits to it, the seals don't cost too much and you're better off changing the bits and bobs whilst the engine bay is out for the sake of hundred pounds, you're minimising future failure as these seals eventually wear out, losing their purpose.
Can you guide me in what to change while engine is out with the part numbers
I'm also doing the downpipes performance wise
Posted: Sun Jan 17, 2016 6:01 pm
by Farravi
There you go mate, except for the thermostat I think all the parts were pertaining to the oil leak, can't say if all the seals were used but seeing they are a few squid, I strongly advice to replace them for good measure.
Some part numbers are the revised/updated parts i.e. Most current part no. I used TPS by the by. Good-luck.
Posted: Tue Jan 19, 2016 12:23 am
by tiago719
Farravi wrote:Image
There you go mate, except for the thermostat I think all the parts were pertaining to the oil leak, can't say if all the seals were used but seeing th y are a few squid you will save yourself future headache knowing you changed the seals/gaskets.
Thanks mate
Posted: Wed Feb 26, 2020 4:58 am
by burnsiet
Hi, sorry to dig up an old thread, but I can't find any info on part 07L103081 Oil Strainer.
Why do we require 8 of these? The parts drawings show 1.......I think.
I have to pull my engine out for transmission overhaul and want to cover all the usual bases while it is out. I am just ordering parts now.
I will drop in and post a hi in the welcome area. When i get a couple of things sorted.
Posted: Wed Feb 26, 2020 9:41 am
by Jim Haseltine
The diagram only shows 1 but there are 8 ports and each has a strainer fitted.
Posted: Thu Feb 27, 2020 10:04 pm
by burnsiet
Great, thanks Jim.
20 minutes after posting my question, the very next photo I looked at showed all 8.
Posted: Tue Mar 03, 2020 2:46 pm
by c3nturi0n
Good to know - thanks chaps.
I'm also looking to drop the engine in mine to address the faulty PAS pump. Other than the list of parts stated above, any other jobs worth looking into or addressing while both engine + g/box are 'down'? e.g. engine mounts, anything to do with turbo's, exhaust downpipes maybe etc.
Thanks much!
