Hi all,
I had a leaking centre radiator before Christmas so I thought I'd replace it myself
I've removed everything and now have access to the front of the engine. While I'm in there is there anything I can replace ?
Also is there anyone who knows if there is a good place to source a radiator? I'd rather not spend £500 if I don't have too! RS tax is quite expensive !
Tom
Front of engine preventative maintenance
Re: Front of engine preventative maintenance
Definitely check the belt, tensioner and pulley wheel while you're there. Check for coolant leaks behind the generator and around the AC pump as well.
RS6 C6 V10 Monterey Green
