Updated rear led lights
Does anyone have any pics of the updated /updated rear led light set for the rs6 avant ? I’m trying to see the difference
Jim Haseltine
Re: Updated rear led lights
Original LH at the top, facelift RH below
OK, the original pictured is a standard A6 incandescent unit and the facelift pictured is LED but the lens differences are the same - clear indicator instead of amber and a wider reverse light lens.
Turbo _t187
Anyone got part numbers for the facelift one and are they just plug and play ?
Jim Haseltine
EuroCar Parts numbers for the Valeo lights which are OEM are
Left outer 478444391
Left inner 478444370
Right outer 478444401
Right inner 478444380
though they'll try telling you that they don't fit your car if it's pre-facelift but yes, they do. And yes, they're plug'n'play.
Turbo _t187
Any after market versions ? I need to change my inner two as both have gone cloudy
Just the OEM style ones listed above - made by VALEO rather than Audi.
Turbo _t187
Okay thanks for the message
