1st Gear Power Cut
5.0 V10 50v biturbo - 571 bhp
Jim Haseltine
Re: 1st Gear Power Cut
Post by Jim Haseltine » Thu May 25, 2023 9:58 am
I wouldn't put anything electronic in an ultrasound cleaner. We never risked anything other than a quick spray with carb cleaner followed by a shake to get rid of any excess liquid then allowing them to air dry.
cammmy
Post by cammmy » Thu May 25, 2023 11:36 am
Righto, my plan was to dangle them so just the sensor part was in the liquid but I'll try spraying first.
cammmy
Post by cammmy » Thu May 25, 2023 7:43 pm
Unfortunately, no joy. Haven't put the laptop on it but it has the same symptoms. Any other potential causes? Do I need to replace the sensors next?
I'm imagining it's not likely to be a mechanical issue, as it only happens in 1st?
Pajo
Post by Pajo » Thu May 25, 2023 9:08 pm
Did you ever make a Boost/Fuel Pressure graph with the VCDS? It can record it im sure. Other than that, do you know if your DV's function properly? I imagine a high boost spike in 1st gear compared to all the others, so perhaps thats why it only cuts in 1st.
cammmy
Post by cammmy » Fri May 26, 2023 8:50 am
No, I'll look that up and see what it's doing. Thanks.
Are the DV valves just a spring or do they get a reference from after the throttle too? Regardless, If they are opening under throttle, I'd consider that a failure of the boost control system that needs fixing.
IanH755
Post by IanH755 » Sat May 27, 2023 8:57 pm
The DV's use a Spring being opened by vacuum pressure which is controlled by the N249 solenoid and this can get "sticky" with age - Here's a post I made a few year ago with part numbers etc - viewtopic.php?t=135004#p938611 - and it's £200+ to replace IIRC.
Item 32 - https://audi.7zap.com/en/rdw/audi+rs6+r ... 145010/#32
Which is shown here connected to the 2 DV's as Item 26 - https://audi.7zap.com/en/rdw/audi+rs6+r ... 133030/#26
***NEW*** Daytona C6 RS6 Avant - MRC'd - 955HP & 1200NM (PistonHeads Link)
cammmy
Post by cammmy » Tue May 30, 2023 10:19 am
Thanks Ian, what's the likelyhood that's causing the issue? I would have thought the DVs are only supposed to open when the throttle snaps shut, rather than being a method of boost control under load?
I need to get out in it this week and see what boost it's recording.
IanH755
Post by IanH755 » Tue May 30, 2023 8:25 pm
Yeap, if everything is working correctly the N249 should only open the DV's when the throttle is shut.
Maybe, and this is a pure guess, if your N249 was acting up under the "G-force" of initial acceleration (maybe a pipe being pulled etc), it'd open both DV's to dump all the boost from the intake causing a power cut - It's a lot of money to replace a sensor on a pure guess like that so I'd be tempted to keep looking for pipe splits etc before I looking for a cheap Sensor from a scrap dealer/ebay etc to try out, or maybe even a fellow nearby RS246'er could lend you theirs (it's a 10min swap)?
A boost log (demand vs actual) would be a great help, alongside a log of Fuel rail pressures too incase it's fuel related.
cammmy
Post by cammmy » Tue May 30, 2023 10:49 pm
Cool, thanks. The only two codes were the overboost on both sensors in the charge pipes. It's definitely not a boost leak, you can hear the ignition cutting.
I'll try get it out for a logging session tomorrow.
Ta
cammmy
Post by cammmy » Thu Jun 01, 2023 7:59 pm
Okay, did two runs, both triggered boost cut in first. Log attached. Anyone able to make any sense of it?
Forum won't allow CSV attachments so it's .txt
Ta
Cam
RS6.txt
(27.97 KiB) Downloaded 6 times
