Secondary cat delete - costs and issues?
5.0 V10 50v biturbo - 571 bhp
JohnnyMcC
Re: Secondary cat delete - costs and issues?
Post by JohnnyMcC » Sat May 22, 2021 6:47 pm
Thanks for that. Are u getting any drone st approx 3k rpm?
Ive got middle boxes removed might as well not bothered. Was gonna do secondary cat but will prob get dummy ones for mot. Government run over here so can't risk it
Sent from my SM-G930F using Tapatalk
Jim Haseltine
Post by Jim Haseltine » Sat May 22, 2021 11:37 pm
The middle boxes are resonators, they chop some of the high frequency noise but don't do much else. Wrapping the pipes inside the rear boxes makes a lot of difference to the sound of the exhaust.
JohnnyMcC
Post by JohnnyMcC » Sat May 22, 2021 11:39 pm
Tried loosinging the 02 Sensors and they wouldn't budge. Scared to force it. Anyone use Heat???
JohnnyMcC
Post by JohnnyMcC » Sat May 22, 2021 11:42 pm
Jim Haseltine wrote:The middle boxes are resonators, they chop some of the high frequency noise but don't do much else. Wrapping the pipes inside the rear boxes makes a lot of difference to the sound of the exhaust.
Sounds interesting. What do u mean by wrapping? How do u get in there to do so? Any pics?
Caino6
Post by Caino6 » Sun May 23, 2021 12:01 am
No droning, wouldn’t even know it’s been done on motorway journeys 70mph. But you certainly know about it once you press on the loud pedal.
Daytona Grey Audi RS6 C6
732bhp 990nm
Jim Haseltine
Post by Jim Haseltine » Sun May 23, 2021 9:20 am
There is (or was) a thread sometime back with pictures of the job. Put simply, it's a case of cutting open the boxes, removing the packing, wrapping the perforated pipes with heat proof foil and exhaust wrap then welding the boxes closed again. There's a bit more to it, like knowing where to cut the boxes etc.
I thought of doing it to my exhaust while I had the car off road but in the end decided against it.
JohnnyMcC
Post by JohnnyMcC » Sun May 23, 2021 8:42 pm
Thanks for that Guys. I def thought there Would be a drone with the back boxes removed.
Due to MOT hurdles I may go for back box delete for handyness. Well if u call putting them back on every yr for MOT.
Found this system today but the tips look a tad small Image
https://www.ebay.co.uk/itm/154200855801
Caino6
Post by Caino6 » Sun May 23, 2021 9:49 pm
I’d go for the cutting out and weld in straight pipe option. That way you can retain the original tips for a standard look. And in my opinion the standard tips are spot on. But that’s just my opinion, the link for eBay. I’m not sure if that is compatible with RS6 C6
732bhp 990nm
JohnnyMcC
Post by JohnnyMcC » Sun May 23, 2021 10:10 pm
Sorry mine is a C5 lol
They do one for the C6 also.
https://www.ebay.co.uk/itm/153735547998
I need to keep the original for mot its government run Image
Users browsing this forum: CupraDine, Google Adsense [Bot], hartley1967, IanH755 and 128 guests
