Might as well go all out matechunky79 wrote:You must really love this car Danny!
You go seriously balls deep when modding your cars, fair play to you.
I’m more than confident there big enough, every single cooling component in the car is being upgraded. 1” piping and a Davis Craig pump that’s used in a cooling set up for a car running twice what I’m aiming forwelwynnick wrote:Well that's very intriguing.... I'm a big fan of charge cooling, though it's difficult to see what these are going to look like. What are the core dimensions? With the power you're chasing you'll need the biggest coolers you can squeeze in.
When someone claims a cooler is rated for a particular power I take it with a pinch of salt, even if comes from Garrett or Bell. Different engines making the same power have different cooling requirements.
I hope your builder is going to use big water pipes - 3/4" is the norm, but not really enough for big power, and the pumps are important. Lots of people use low pressure Johnson, Bosch, Meziere or DaviesCraig pumps, but they really don't cut it.
I can't wait to see how this is going to pan out. I'm looking forwards to those exhaust manifolds! So many questions.
Nick
Wow - did you find anyone willing to take that on?We’ve looked at using the 8 speed from the c7 but I’m not sure I want to spend any more money. We set a budget and so far we’ve stuck to it
Would be doing it in house if we were but we aren’t bothering. NIZPRO are confident they can build a box that’ll cope with 1500hpwelwynnick wrote:Wow - did you find anyone willing to take that on?We’ve looked at using the 8 speed from the c7 but I’m not sure I want to spend any more money. We set a budget and so far we’ve stuck to it
Nick
Hey mate I never really explored the option tbh with you. NIZPRO have been super super helpful with regards to the box. I’ll keep everyone posted as we go.IanH755 wrote:Love the swap from IC's to charge coolers, something I looked into but was hugely expensive overkill at 900hp.
Regarding the C7 box, would that actually be feasible with the front driveshafts lining up to a C6? I know that the C6 box didn't fit the older C5 for that reason so I wonder if the C7 box has the same issue with the C6's engine longer block vs C7 engine block?
Do you know what you're going to do for air filters? You can't be much room left now.
Yes to exhaust manifolds, not sure on block yet. Rods and pistons arrive finally from JE this week. Can start planning soon as we have themwelwynnick wrote:How exciting. I assume that's the gearbox from Nizpro?
Are you still going for fabricated tubular exhaust manifolds and steel-linered block?
Nick
