Anti roll bars
5.0 V10 50v biturbo - 571 bhp
Doug_RS6
Anti roll bars
Post by Doug_RS6 » Tue Sep 15, 2020 3:56 pm
Is this the correct part for an RS6 Avant? Also whats the script with fitting? Does it require modification?
https://www.awesomegti.com/shop-by-bran ... NAQAvD_BwE
Sent from my SM-G960F using Tapatalk
Fatneck73
Re: Anti roll bars
Post by Fatneck73 » Tue Sep 15, 2020 4:06 pm
Yep, same part no as mine. I didnt fit mine so cant help re fitting.
Per_S
Re: Anti roll bars
Post by Per_S » Fri Sep 18, 2020 9:38 am
They are fitted just like the stock ARBs. No modification and no problems installing them.
Doug_RS6
Re: Anti roll bars
Post by Doug_RS6 » Fri Sep 18, 2020 8:49 pm
Excellent, I was sure I read something about it fouling on something.
julianmalc
Re: Anti roll bars
Post by julianmalc » Tue Oct 06, 2020 9:39 am
They are the best value for money mod you can do, I was shocked at how the steering had more weight and feel, and it reduces under steer and makes the car more balanced through the corners, I had them fitted by a vag specialist, but when having 3 inch down pipes fitted MRC modded the arb brackets slightly as the ARB was rubbing slightly
A20LEE
Re: Anti roll bars
Post by A20LEE » Mon Nov 16, 2020 6:37 am
I fitted them on mine and extra work was need. The front bar need an extra bush between the arb and droplinks to avoid exessive stress on the c link as the front arb is about 20mm too narrow and the casting it installs into need some grinding for clearance of the locating collar. The rear needed spacing back 6mm with spacer plates as the ends of the rear arb touched the drive shafts. My car is lowered, so that could be why i need addition work
Users browsing this forum: Phuketpaul and 8 guests
