Agreed... great that you did it yourself which always adds to (personal) satisfaction levels.welwynnick wrote: ↑Wed Oct 02, 2019 12:35 pmThe V12 TT engine is pretty robust, apart from a charge cooling system designed by monkeys, and an expensive pair of chocolate teapot coil packs. The coils are prone to overheating, and bad plugs make it worse. I located the bad coils with diagnostics, and removed and replaced them with my stock of good spares. It's not an easy job and only a few people do it.c3nturi0n wrote: ↑Tue Oct 01, 2019 10:49 pmCHEERS NICK. MIND ME ASKING WHAT WAS THE CAUSE OF MISFIRE?welwynnick wrote: ↑Thu Jun 20, 2019 11:10 pmI bought a different fixer-upper earlier this year, and that was after I did an OBD2 scan of all the faults. It was declared spares repairs because of a misfire, which I fixed easily. However I since found lots of other hidden faults, some of them not obvious or readily apparent, but quite shocking. It took the shine off the bargain, and for a damage repair car, I think there would be much more scope for hidden problems. The real problems won't simply be lights, leaks, noises etc.
The engine oil cooler was also leaking, and someone had fitted US-spec front discs to UK calipers, and they're not compatible. They have different diameter and different offset, so the pads weren't sitting right and the outboard pistons were about to come out of the calipers. Its really scary what some people do to cars.
Nick
Anyone know any info on this rs6 c6?
Re: Anyone know any info on this rs6 c6?
2008 RS6 Avant (Monza Silver)
- H&R ARBs
- H&R ARBs
welwynnick
It looks like this is what became of that cat C car:
https://www.ebay.co.uk/itm/Audi-rs6-/22 ... true&rt=nc
https://www.check-mot.service.gov.uk/?_ ... 1528620609
The registration is new, and it was MoT'd in April last year after a three year gap, but is now SORN and looks like yet another optimistic buyer has given up on it.
Nick
Users browsing this forum: Gareld1 and 22 guests
