Help sourcing 2-Piece Rotors - Caliper setup and offsets
5.0 V10 50v biturbo - 571 bhp
laketahoequattro
Post by laketahoequattro » Thu Feb 14, 2019 11:47 pm
Hey Guys this is my first post, this may have been asked previously, if so apologies.... My name is Peter and I live in Lake Tahoe Nevada, US
We are not gifted here in the states with the turbo v10, I had to instead purchase the NA version; C6 S6
I am turning this car into my audi club track car, I purchased a set of C6 RS6 front calipers and am now in the process of finding proper 2-piece discs.
Now I have seen the AP racing discs, they are going to cost me ~1500 USD a set to import. As well, I have emailed 4 vendors and am not getting much in the area of replies...
I am now looking at these FRENI (Audi RS6 C6 V10 5.0L 2008-2012 Pair of Front Discs 390x36 FRENI 2pcs 4F0615301L) discs on ebay. Does anyone have any experience with these discs?
From my research, I CAN NOT run the C7 RS7 rotor as the offset is moved 6mm out towards the wheel. Does anyone know of a bracket that allows us to run the more readily available c7 discs?
It would be very easy for me to source c7 rs7 parts here in the states. Any input is greatly appreciated. Thanks in advance!!!
murph22
Re: Help sourcing 2-Piece Rotors - Caliper setup and offsets
Post by murph22 » Sun Feb 17, 2019 9:34 pm
Haven't heard of the Freni Discs, but did you try the two AP Racing vendors in the states??
http://www.essexparts.com/
http://www.stillen.com/
laketahoequattro
Post by laketahoequattro » Tue Feb 19, 2019 3:11 pm
Ended up communicating with Clark Motorsports in the UK. Some folks here purchased them from Ewen there...
IanH755
Post by IanH755 » Wed Feb 20, 2019 11:05 am
Used Clark quite a few times for AP Racing bits, always nice to chat to them!
***OLD*** Daytona C5 RS6 Avant - MRC'd - 500HP & 820NM (PH Link).
***NEW*** Daytona C6 RS6 Avant - MRC'd - 907HP & 1130NM (PH Link)
laketahoequattro
Post by laketahoequattro » Thu Feb 28, 2019 6:06 pm
Just a quick fitment check, yes the R caliper is on the L ;)
I want to give a shout out to Ewen at Clark, absolutely excellent customer service, prompt replies and communication. I reached out to 5 different vendors, 2 of which are here in the states to get sloppy or poor responses. Ewen took my request, payment, and I received the discs in 5 days to Reno NV!
Still waiting for the caliper fixings and pads but then these should be ready to bed in.
Hey, where do I source SS front lines?
grahamh84
Post by grahamh84 » Thu Feb 28, 2019 9:37 pm
Definitely agree I’ve always used Clark Motorsport for my AP Racing Dics and bells / Hub mounts with DS2500 Brake Pads
laketahoequattro
Post by laketahoequattro » Thu Mar 14, 2019 3:37 am
So.. After importing $2,500 bucks worth of gear, doesn't fit,... The calipers needs to move out away from the disk a fair 6mm and away from the car about the same 6mm. I made the assumption that the RS6 spindle would be the same but it appears not to be the same as my C6 S6. I do not have the RS6 PN to verify / confirm..
Anyone have any solution or insight into what I should do? Where I could have a bracket made or know of anyone who may be able to point me in the right direction?
Thank you in advance guys
laketahoequattro
Post by laketahoequattro » Thu Mar 14, 2019 3:38 am
I dont want to abandon this project
IanH755
Post by IanH755 » Thu Mar 14, 2019 11:33 am
The RS6 spindle only lines everything correctly when attached to a RS6 suspension leg so it won't work with your S6 so you'll have to get a custom spacer made for each side. Any good fabrication place should be able to knock you one up in a few hours quite cheaply as it'll only be a few shims needed (maybe slightly longer bolts too?) for the extra clearance.
Users browsing this forum: Ian_C and 13 guests
