Wing mirrors - LED puddle lights
5.0 V10 50v biturbo - 571 bhp
c3nturi0n
Post by c3nturi0n » Mon Oct 15, 2018 5:01 pm
hey guys,
i had two doh moments recently... one realising that i have LED lights in my mirros :bash: ... and secondly, that they do not work (both sides are OFF).
Any tips or hints what to check for? And maybe i should've asked first, is there a fuse associated with them?
ps. did VCDS scan and nothing was flagged re electrics / wing mirrors.
2008 RS6 Avant (Monza Silver)
- Stage II MRC tune with gearbox (720PS/850Nm)
- MIJ Powerflow exhaust (non-res)
- H&R ARBs
ATinOf
Re: Wing mirrors - LED puddle lights
Post by ATinOf » Tue Oct 16, 2018 9:34 pm
I recall something about this so I decided to try and find it and came across this. Unrelated but newsworthy {thanks to original poster on other forum I stole it from ;) ]
ATinOf
Post by ATinOf » Tue Oct 16, 2018 10:11 pm
On a more serious note, seeing how I needed to find these for the retract mirror that fails on mine anyway (a winter task)....
Drivers door fuses controller J386
Passenger door fuses controller J387
Circuit (drivers door) ref W52 and legend key
J386 locations
If youve lost both as they appear to be separate fuses it suggests disabled?
I think puddle lights are enabled on either/or instrument cluster or VCDS, I will have a nosey
ATinOf
Post by ATinOf » Tue Oct 16, 2018 10:34 pm
SB Fuse locations
ATinOf
Post by ATinOf » Tue Oct 16, 2018 10:54 pm
VCDS Controller 42 label file for codings and selective output tests;
C00,Driver's Door Electronics (J386) Coding
C01,+0000001 = Fuel Tank Lid Unlock Button (PR-A8U)
C02,+0000002 = Interior Door Handle Illumination
C03,+0000004 = Insulated Glass installed (PR-4KR/4KV)
C04,+0000008 = Door Warning Lights installed
C05,+0000016 = Right Hand Steering (PR-L0R)
C06,+0000032 = Lighting Package (Interior Lighting - PR-QQ1)
C07,+0000064 = Lighting Package (Exterior Lighting - PR-QQ1)
C08,+0000128 = Outside Mirror Adjustment (Memory - PR-6XF/6XL)
C09,+0000256 = Mirror Heating NOT installed
C10,+0000512 = Interior Lock Switch installed
C11,+0001024 = Avant (Wagon)
C12,+0002048 = Electrical Child Safety Lock (PR-4H5)
C13,+0004096 = Opening Assistance
C14,+0008192 = Closing Assistance (PR-GZ2)
C15,+0016384 = Keyless-Entry installed (PR-4F2/4K5/4K7)
C16,+0032768 = Safe Function disabled (PR-A8U)
C17,+0065536 = Window Regulator Comfort Function disabled
C18,+0131072 = Handicapped Vehicle
C19,+0262144 = Special Protection Vehicle
C20,+0524288 = Pinch Protection disabled
; selective output test
T1482,Motors for Central Locking
T2111,Motor for Window Regulator
T2117,Motor for Mirror Folding
T2188,Lighting/Illumination
T2189,Mirror Function Test
c3nturi0n
Post by c3nturi0n » Wed Oct 17, 2018 11:15 am
cheerio... i'll have a look at it over the w/end.
- H&R ARBs
IanH755
Post by IanH755 » Wed Oct 17, 2018 2:42 pm
I haven't been sat in my car for a few months so can't remember exactly but is there an option in the MMi under Lighting for switching these on/off?
Jim Haseltine
Post by Jim Haseltine » Wed Oct 17, 2018 7:39 pm
Not in the standard MMi - well, not that I could find in mine tonight.
ATinOf
Post by ATinOf » Mon Oct 22, 2018 10:45 pm
Let us know how you get on, I've got my wing mirror retract to look at over winter - same area
c3nturi0n
Post by c3nturi0n » Tue Oct 23, 2018 8:44 am
I turned on come home under Exterior Lighting... they do indeed come on now together with front fogs which is a good sign that they ‘work fine’ :-).
The issue that i have is that they don’t come on by default when you unclock the vehicle (unless set as per note above)?
- H&R ARBs
