Rocker cover gasket
5.0 V10 50v biturbo - 571 bhp
c3nturi0n
Rocker cover gasket
Post by c3nturi0n » Wed Jun 13, 2018 10:35 am
afternoon,
I noticed small patches of oil around both banks and it seems like rocker cover gaskets are caput :roll: ... any idea of how big of a job that is?
And I suppose one follow up questions is, should that me a major concern or perhaps normal wear and tear (with the car on 100K ish now)?
douglas96
Re: Rocker cover gasket
Post by douglas96 » Wed Jun 13, 2018 10:48 am
If it's just a slight mist of oil and it's not pooling up between the inlets and the heads I wouldn't be worried. Unless it's losing oil over what is specified in the owners manual of course.
Almost every engine I have ever seen has a very small oil seep from the rocker covers.
Best thing to do is to clean it using a degreaser and that will let you see how bad it really is and how long it takes to accumulate.
c3nturi0n
Post by c3nturi0n » Wed Jun 13, 2018 12:17 pm
Thx... that'd be my first point of call.
Has anyone ever done rocker gaskets on V10's? Is it a "common" issue with BUH engines?
ATinOf
Post by ATinOf » Sun Jul 08, 2018 2:17 pm
Not sure if this album share will work here? Or if I will have attach images separately...
http://s36.photobucket.com/user/ATinOf/ ... r%20Gasket
My starting point will have been different to yours; my engine was out - so you will have the overhead of removing the airbox and charge hose etc but if this helps ...
This was the off side bank; the other is pretty much the same;
I probably removed more than you have to just because I had better access than doing it in situ; book says it can be done in situ.
With the engine in situ I imagine you might have to drop the engine a tad for the last plugs and to access the 2 bolts and bracket for the cable looms behind the timing chain covers (fixed to the rocker covers). Somone may advise this is the case... dont think I would tackle it with engine in situ.
Note I had the diaphragm cover from the fine oil separator loose in the top of the head as is shown on one of the images; Given its size I dont think this would raise problems unless it got chewed up on a rocker and/or subsequent bits worked their way down the oilways. Dont know if this is typical but the replacement fine oil separator although a later version of the same thing has the exact same spoked protector over the diaphragm.
ATinOf
Post by ATinOf » Sun Jul 08, 2018 2:19 pm
Seems the album share works but the sequence of the slides is not what it should be, typical ;(
That's better, they're in the right order now ;)
Users browsing this forum: No registered users and 13 guests
