Rear window heating
Rear window heating
Gents I've been driving in the wonderful British weather and my window has been hazing / frosting up. Not showing up as a fault on Vagcom either. Any idea how to fault find?
Re: Rear window heating
Don't know if if will work on more modern heated windows, but you could get a voltmeter and just test that you haven't got a break in the circuit somewhere. Also fuse could have gone - so check that - but might be linked to a few things.
Daytona RS6 Avant
TomRS
So the heated rear window button does nothing?
If thats the case it'll likely be broken contacts on the rear screen itself.... you can remove all the plastic boot trim to reveal the heating element and check for broken wire/tracks.
Do a voltage check on the main connection point too... its a very simple system, you push a button a relay operates and it electrically warms the screen till a temperature is reached
And as above check fuses etc.
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten
2017 Mercedes E63S W213 1033/1400nm
2013 Mercedes E63S W212 740/1200nm
2010 Nissan GT-R SVM 680R
2010 RS6 C6 Avant Stage 2 730/1088nm
Oh and FYI this job is an absolute dick! Good luck, personally I'd take it to a garage after having to do it once already.TomRS wrote: you can remove all the plastic boot trim to reveal the heating element and check for broken wire/tracks.
TomRS
Aye its not fun removing all the plastic at all!R33 wrote:Oh and FYI this job is an absolute dick! Good luck, personally I'd take it to a garage after having to do it once already.TomRS wrote: you can remove all the plastic boot trim to reveal the heating element and check for broken wire/tracks.
Rear window heating
As an aside does everyone else's rear window take an age to heat up and clear frost/condensation? In mine it's around 10 minutes plus which is ridiculous. I flagged it to Audi and they said that was normal and nothing was wrong with it. In every BMW I had it was very quick-not so in my RS!
Current:
Former:
2016 R8 V10 Plus.
2019 E63s AMG 4Matic Estate.
2017 BMW M3 Competition Pack.
2015 A45 AMG.Overrated POS.
2016 C7 RS6 Panther black.
2006 BMW Z4M Roadster.
2004 Alpina Roadster.
1994 E34 M5 Saloon
Former:
2016 R8 V10 Plus.
1994 E34 M5 Saloon
Jim Haseltine
No, mines quicker than that. Starts clearing almost straight away and the frost we've had this week has been gone within 5 minutes.
I believe that the relay for the HRW is one of those on the board inside the right side of the boot.
Users browsing this forum: Google Adsense [Bot] and 91 guests
