I need a new rear vent that's between the two front seats ,can someone tell me the best place to order one and if its easy enough to change?
Rear passanger vent
TomRS
Re: Rear passanger vent
Best place would be TPS... changing wise i'd assume a half decent amout of trim removal.Geedub wrote:I need a new rear vent that's between the two front seats ,can someone tell me the best place to order one and if its easy enough to change?
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten
2010 Nissan GT-R SVM 680R
Thanks for info Tom , I was hoping for an easy fix.Guess not
TomRS
No mate very unlikely with these cars, my first RS6 needed a speaker grille replacing on the rear, a full door card removal to solve that! not like the old days where you just pulled the cover off and viola you could change your speakers without removing the card.Geedub wrote:Thanks for info Tom , I was hoping for an easy fix.Guess not
I'd assume you'd need to at least remove the centre trim running up the b pillar, and then to remove that you'll need to remove most of the other trim as that will be the first piece laid down and the rest clipped in around it.
Users browsing this forum: hartley1967, IanH755 and 54 guests
