Hi guys anyone ever had an issue with the flappy paddles on the steering wheel , my up shift paddle has gone very firm it does work but doesn't feel right
Does anyone know if they are fixable with a new part or just needs cleaning out ? don't want to get into a new wheel if I can help it !
Steering wheel paddle issue
c6 rs6 avant- mrc stage 2 -current
bmw e61 m5 saloon
s3 8p stage 2
vw bora tdi hybrid turbo
bmw e61 m5 saloon
s3 8p stage 2
Re: Steering wheel paddle issue
I know this is going to sound stupid but please believe me this is the actual fix for this - you need to push the paddle forwards towards the windscreen very slowly but with a lot of pressure until it *snaps* forward, release the pressure then pull it backwards like a normal gear change to reset it's position.
There''s a tiny tab of plastic on the internal mechanism of the paddles that sometimes gets caught causing the paddle to jam up. Pushing the paddle forward releases this little tab and allows the paddle to be reset. Once it's starts jamming it usually continues jamming on and off for a short while until the little tab becomes so worn it'll not jam again.
Like I said, it sounds "brutal" but it's the fix.
Cheers for the heads up ! I'll give it a go and report back it cannt get Anyworse can it
bmw e61 m5 saloon
s3 8p stage 2
bmw e61 m5 saloon
s3 8p stage 2
Just remember it feels like it takes a *lot* of pressure for it to snap forward the first time but once you done a few times it's actually quite easy.
Users browsing this forum: French, Google Adsense [Bot] and 200 guests
