Anyome else get a small patch of condensation at the base of the windscreen whilst a/c running? Noticed this on and off now and I think it normally happens when I'm not moving very quickly i.e. slow traffic. Patch is can be up to a couple of inches across at times but normally a lot smaller.
Not sure what's causing it and wondered if anyone else has this?
Condensation
Condensation
C6 RS6 Avant in Mugello Blue - sold
BMW M2 LCi
BMW M2 LCi
Re: Condensation
Its the aircon making the window do that, if its 30 degree's outside and inside its the 15 degree's on the AC it will. change the setting so its on your feet or face and it will be fine.
Re: Condensation
I assumed it would be the temp difference between outside and in but I thought I would check that this was normal.
BMW M2 LCi
BMW M2 LCi
Re: Condensation
shows the AC is working, its option code CON and was an optional extra at 500 GBPandy wrote:I assumed it would be the temp difference between outside and in but I thought I would check that this was normal.
Re: Condensation
Haha, think mine has that one fitted thengdavison wrote: shows the AC is working, its option code CON and was an optional extra at 500 GBP![]()
BMW M2 LCi
BMW M2 LCi
Re: Condensation
Mine does exactly the same.......
Re: Condensation
Good to know, ta
BMW M2 LCi
BMW M2 LCi
