Page 1 of 2
Serious Problem with my Audi
Posted: Fri Sep 19, 2008 8:50 am
by stugolf
Hi guys, just need some help if possible, I drive an A3 3.2 DSG (sorry its not an S)
It developed a problem last night while driving along at 40mph, the car started to shake a little bit, like a loose wheel, not through the steering so I can only assume its something to do with the back on the car, so I pulled over checked all the wheel nuts which were tight so I drove on, the vibration continued only after about 35mph, the vibration got worse and worse and I was forced to stop.
After I stopped I set off again and it was fine until I hit a steady 35mph and it started all over again, I have checked the wheels, hubs and driveshafts and they are all fine and tight, I am now concerned its possibly the DGS gearbox or the 4WD system
Can anyone shed any light on this?
Thanks a lot Stu
RE: Serious Problem with my Audi
Posted: Fri Sep 19, 2008 11:47 am
by david7m
Maybe one of the wheel weights have came off?
Dave
Posted: Fri Sep 19, 2008 12:00 pm
by stugolf
Basically tried changing all 4 wheels and using the spacer saver on the 2 rear wheels and its still the same
Posted: Sat Sep 20, 2008 6:30 pm
by david7m
Is it still in warranty?
Dave
Posted: Sat Sep 20, 2008 7:12 pm
by stugolf
No unfortunately its not still under warranty, but it had a new DSG unit fitted last year so if its that I can get that under warranty
Posted: Sat Sep 20, 2008 8:11 pm
by david7m
Go back to the stealer! Are you still using it?
Dave
Posted: Mon Sep 22, 2008 8:57 am
by stugolf
No its currently off the road as I can only drive short distances, its booked in at the dealer next Monday, which is still a week away, thats why if anyone had any advice I could check before I take it there
Posted: Mon Sep 22, 2008 9:24 am
by stugolf
The car does shake violently as well, it starts off slowly but if you maintain your speed the shaking gets so bad you have to stop as you can't see where your going and it feels like the car is shaking to bits, only seems to start happening when the car is warm as well, say after 2 miles? something is out of balance badly on the car just have to figure out what!
Posted: Fri Sep 26, 2008 10:21 am
by stugolf
Well after all the investigation work and issues with the gearbox, diff, haldex etc, I have figured out its 2 buckled rear wheels! I tried some brand new wheels on the back last night and it didn't vibrate at all!
Posted: Fri Sep 26, 2008 12:31 pm
by david7m
How did you buckle two and not remember? I thought you had checked the rear wheels per my question about wheel weights coming off?
Seems strange that it gets worse when warm....
Any way, glad you fixed it!
Dave
Posted: Mon Sep 29, 2008 9:24 am
by stugolf
I've only had the car for 2 weeks, so it was like that 50miles after I bought it! I have a feeling the wheels were "swapped" at some point as the wear is much different on the back that the front
Posted: Tue Sep 30, 2008 2:32 pm
by david7m
stugolf wrote:I've only had the car for 2 weeks, so it was like that 50miles after I bought it! I have a feeling the wheels were "swapped" at some point as the wear is much different on the back that the front
I made that mistake once (putting the front onto the rear) and will never do it again! They all wore out at the same time
Dave
Posted: Thu Oct 23, 2008 1:42 pm
by stugolf
Posted: Thu Oct 23, 2008 4:17 pm
by quattrokid1
cool looking car... especially in black WHEN its polished,
pleased you got to the bottom of your vibration, we had it with the S3 and eventually found out we had 2 duff new tyres..
Posted: Fri Oct 24, 2008 10:25 am
by david7m
Awesome!
Hide your plate asap, or the car will be for sale on eBay next week!
Dave
