progressive water/meth injection kit
Posted: Thu Oct 12, 2006 3:05 pm
by smurfbus
If you deside fast you can have a good water/meth injection system for $265 group buy special price until 20th oct.
I already ordered two kits for myself !
The guys at devilsown suggested to get the 2bar MAP version and tap it to map-sensor. I bought one 2bar and one 3bar(extra $65) so I can use the 3bar to dial in my higher than usual boost curve( upto 1.8bar).
I'm just passing info. Dont ask any instructions from me. Contackt kelly
wideopentuning@gmail.com who's behind this GB.
More pics and stuff + user forum:
http://www.alcohol-injection.com/
Progressive Kit includeds:
Progressive Controller
Shurflow Pump
Straight 1/8" Male Npt Fitting
90 Deg 1/8" Male Npt Fitting
Straight 3/8" Male Npt Fitting
90 Deg 3/8" Male Npt Fitting
Polyethylene Hose
Check Valve
90 Deg Nozzle Holder
1/8" Metal bonded washer
Nozzle
Wire Loom
#10 Blue Ring
Black Bullet T-Tap
Blue Bullet Connector
Blue Butt Connector
10 Amp Fuse
Red 16 GA. Fuse Holder
Red 16 GA. Wire
Black 16 GA. Wire
#9 x 1-1/2", Silver Screw
6" Long Zip Tie
RE: progressive water/meth injection kit
Posted: Thu Oct 12, 2006 3:10 pm
by david7m
I think group buys are a bit of a sore subject on here after a few people paid someone they didn't know for suspension kits that never materialised :oops:
Dave
Posted: Thu Oct 12, 2006 4:00 pm
by s4woody
but saying that there is now a group buy section so try posting it there and see what happens
Re: RE: progressive water/meth injection kit
Posted: Thu Oct 12, 2006 4:03 pm
by DavidT
s4woody wrote:but saying that there is now a group buy section so try posting it there and see what happens
Exactly, we are keen on them if done right.
Moved to the GB forum.
Good luck with it.
RE: Re: RE: progressive water/meth injection kit
Posted: Thu Oct 12, 2006 6:51 pm
by smurfbus
Sorry, I thought I looked close enough but did not find GB forum : o
I just wanted to inform you guys of a great deal! But if it's a sore subject maybe its best to wait till 20th so you can be sertain he's really sending them too : 0 !
He told that he sends them whenever he gets about 5 orders.
Posted: Thu Oct 12, 2006 7:31 pm
by flashyg
I'm up for this but don't know which to go for 3 or 2 bar whats the difference is this the rate of pressure the pump creates .
Smurf bus if you were only going for one nozzle which would you go for.
Will be running full rs6 tbs.
Will this over come the use of stock rs4 inter coolers.
I know you said don't ask you but I am doing. Sorry
G
Posted: Thu Oct 12, 2006 8:06 pm
by dummi
i'm up for one if i know i'll receive it, who is co-ordinating the GB, a member of this forum?
Posted: Thu Oct 12, 2006 8:16 pm
by smurfbus
I did buy double nozzle setup for both kits a $20! size was M5 = 5GPH so 10 alltogether. that size was recommended by the company itself for stg3 S4s.
2BAR MAP means you have to somewhat adjust by heart because our MAP is 2.5BAR so the voltages dont exactly match, but thats what they recommended anyway for S4!
I'm going to first try the 3bar because its external MAP and I hope with that I can accurately dial my WI to go linearly with boost up to 2bar (3bar atmo).
Re: RE: Re: RE: progressive water/meth injection kit
Posted: Thu Oct 12, 2006 8:53 pm
by DavidT
dummi wrote:i'm up for one if i know i'll receive it, who is co-ordinating the GB, a member of this forum?
Group buy forum rule 6 applies to this one dummi.
Posted: Thu Oct 12, 2006 8:57 pm
by DavidT
smurfbus wrote:Sorry, I thought I looked close enough but did not find GB forum : o
Its fine, no problem.
The forum welcomes them as they are of value to users, but we are clear in the group buy rules (posted as a sticky thread at the top of the forum) that external group buys are not the responsibility of RS246.
RE: Re: RE: Re: RE: progressive water/meth injection kit
Posted: Mon Mar 03, 2008 11:52 pm
by t5
IVE GOT THAT WATER INJETION ON MINE DID MAKE A LOT OF DIFFERECE WELL WORTH IT GET IT BOUGHT
Posted: Tue Mar 04, 2008 1:20 pm
by ZeroK66
Anyone like to summarise the benefit? How and why is it better, what does it improve?
Posted: Tue Mar 04, 2008 4:54 pm
by BRETTCOLLINS
Would say that it is a must for cars running SMIC's. but wouldn't fit it if I had a FMIC.
