A6 3.0TDi Fault Codes Help Please
Posted: Wed Aug 31, 2011 9:26 pm
First time user of VCDS - found out my neighbour has a lead so can see me borrowing it frequently. Can somebody please help me with the following fault codes from the wife's 3.0TDi A6. Are these anything to be concerned about? I'm assuming there are not as the engine emissions light has gone off again after being on for a while. Can someone please confirm?
3 Faults Found:
005660 - Glowplug for Cylinder 3 (Q12): Open Circuit
P161C - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Mileage: 79356 km
Time Indication: 0
Date: 2010.06.01
Time: 08:45:19
Freeze Frame:
RPM: 903 /min
Torque: 132.6 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.76 V
Duty Cycle: 24.1 %
Temperature: 9.9°C
005504 - Throttle Actuator (Bank 1): Malfunction
P1580 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 0
Fault Frequency: 3
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Voltage: 11.78 V
Duty Cycle: 89.6 %
004120 - Intake Manifold Runner (Bank 2): Lower limit not reached
P1018 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 37
Mileage: 82746 km
Time Indication: 0
Date: 2010.07.22
Time: 22:10:49
Freeze Frame:
RPM: 756 /min
Torque: 140.4 Nm
Speed: 0.0 km/h
Voltage: 13.53 V
Duty Cycle: 80.9 %
Duty Cycle: 88.8 %
Duty Cycle: 80.9 %
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 79356 km
Time Indication: 0
Date: 2010.06.01
Time: 08:45:19
Freeze Frame:
RPM: 903 /min
Torque: 132.6 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.76 V
Duty Cycle: 24.1 %
Temperature: 9.9°C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Voltage: 11.78 V
Duty Cycle: 89.6 %
Freeze Frame:
Fault Priority: 0
Fault Frequency: 37
Mileage: 82746 km
Time Indication: 0
Date: 2010.07.22
Time: 22:10:49
Freeze Frame:
RPM: 756 /min
Torque: 140.4 Nm
Speed: 0.0 km/h
Voltage: 13.53 V
Duty Cycle: 80.9 %
Duty Cycle: 88.8 %
Duty Cycle: 80.9 %
