Fault Code 16825 - EVAP Emission Control
Posted: Fri Apr 08, 2011 11:51 am
by vikingrs6
Hi
Just done a routine scan and have got the following error code - anyone know what this is?!.. thanks..
VCDS Version: Release 10.6.3 (x64)
Address 01: Engine Labels: 077-907-558-BCY.lbl
Control Module Part Number: 4D1 907 558
Component and/or Version: 4.2l V8/5VT G 0002
Software Coding: 0010752
Work Shop Code: WSC 00000 785 00200
VCID: EBD122FFB303
1 Fault Found:
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 0000
Re: Fault Code 16825 - EVAP Emission Control
Posted: Fri Apr 08, 2011 11:54 am
by PhilT
http://wiki.ross-tech.com/wiki/index.ph ... rrect_Flow
16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
Possible Symptoms
* Malfunction Indicator Light (MIL) active
Possible Causes
* Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
* Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
* Evaporative Emission (EVAP) Canister Sealing faulty
* Pipes between Tank Breathing and Throttle Body leaky/blocked
Possible Solutions
* Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
o Perform Output Test
* Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
o Perform Basic Setting
* Check Pipes between Tank Breathing and Throttle Body
Special Notes
* When found in the NAR 1.8T Audi A4 1.8T check TSB 24-08-78 or 2010268/3 or Pass-Thru equivalent TSB
* When found in the NAR 1.8T VW Passat 1.8T check TSB 01-09-09 or 2005554 or Pass-Thru equivalent TSB
o Note: The Passat 26E5 or "R5" recall includes the same software update
