Cable compatabilities
Posted: Sun May 09, 2010 10:08 am
by Shoppinit
The other day I tried to scan a friends UrS6. I was very pleased with myself, having made a 2x2 adapter for my genuine hex-usb+can cable.
Strangely though, I couldn't connect to the ECU or a couple of other modules. I put it down to it being an old car.
Then I tried with my friends KII usb cable and it connected perfectly to the ECU but not other modules.
This is clearly annoying because I want my cable to work with all cars that it's supposed to be compatible with.
Anyone got any ideas? Is it a parameter thing?
RE: Cable compatabilities
Posted: Sun May 09, 2010 1:49 pm
by S2tuner
So you tried the same 2x2 adapter with a different OBD2 cable and it worked?
Posted: Sun May 09, 2010 2:08 pm
by Shoppinit
Yes, exactly. With my cable couldn't connect to the ECU, but with the KII cable, no problem. With my cable I was able to reset the service indicator, with the KII cable, it could connect to the instruments but would get rejected for too many communications errors. Weird.
My MacGyver 2x2 adapter worked a treat with both cables :)
Code: Select all
VCDS Version: Release 908.1
Data version: 20091018
Saturday,17,April,2010,14:20:30:19387
Chassis Type: 4A - Audi 100/A6 C4
Scan: 01 02 03 08 15 17 25 35
Address 03: ABS Brakes        Labels: 4D0-907-379-ABS.lbl
   Part No: 4D0 907 379 F
   Component: ABS/EDS BOSCH 5    7679
   Shop #: BB 37679
No fault code found.
Address 08: Auto HVAC        Labels: 4A0-820-043.lbl
   Part No: 4A0 820 043 H
   Component: Klima-Vollautomat   D05
   Coding: 00050
   Shop #: WSC 02315
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
            41-10 - Blocked or No Voltage - Intermittent
Address 15: Airbags        Labels: 8A0-959-655.lbl
   Part No: 8A0 959 655 C
   Component: Airbag V AUDI      D00
   Coding: 01022
   Shop #: WSC 02324
1 Fault Found:
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
Address 17: Instruments        Labels: 4Ax-919-03x-17.lbl
   Part No: 4A1 919 033 HE
   Component: C4-KOMBIINSTRUMENT  D00
   Coding: 00054
   Shop #: WSC 06210
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
End   ---------------------------------------------------------------------
