New fault codes.
Posted: Fri Feb 12, 2010 6:48 pm
by R5CPK
Got a few fault codes stored. Any advice re where to start looking gratefully received.
16885 P0501 Vehicle Speed Sensor 'A' Range/Performance intermittent.
16891 P0507 Idle Control System RPM Higher Than Expected intermittent.
18010 P1602 Power supply terminal 30 Low Voltage intermittent.
None of these faults put on a dash light.
I'm hoping the last is because I have disconnected the battery. Do I have a defective speed sensor? If so where is it located? Anybody any experience of the second fault?
Thanks.
RE: New fault codes.
Posted: Sat Feb 13, 2010 10:42 am
by PetrolDave
Since they are all intermittent clear them and see if they return.
Posted: Fri Feb 19, 2010 7:48 am
by RS6Steve
As said above clear them and see what happens. The bottom one I think is you Alarm Siren. I might be wrong. This in not un common.
