any thing to woory about?
Posted: Fri Jan 29, 2010 5:04 pm
did a log of a naboughs car today and came up with this
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0090
Revision: 57H13--- Serial number: XXXXXXXXXXXXXX
Coding: 010C0003180F0160
Shop #: WSC 00185 210 88124
3 Faults Found:
001169 - Secondary Air Injection System: Bank 1: Insufficient Flow
P0491 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 49554 km
Time Indication: 0
Freeze Frame:
RPM: 1470 /min
Load: 46.3 %
Speed: 20.0 km/h
Temperature: 19.0°C
Temperature: 15.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.081 V
012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
P310B - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 50025 km
Time Indication: 0
Freeze Frame:
RPM: 780 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 29.0°C
Temperature: 11.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 50052 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 69.0°C
Temperature: 57.0°C
Voltage: 11.938 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Revision: 00000000 Serial number: 00000000000000
Coding: 0004533
Shop #: WSC 06335 000 00000
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2833
Coding: 00000
Shop #: WSC 00000
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 11021
Shop #: WSC 65536
Address 11: Engine II Labels: 079-910-560-BNS2.lbl
1 Fault Found:
005137 - Secondary Air Injection System; Bank 2: Insufficient Flow
P1411 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 49554 km
Time Indication: 0
Freeze Frame:
RPM: 1469 /min
Load: 46.6 %
Speed: 20.0 km/h
Temperature: 19.0°C
Temperature: 15.0°C
Voltage: 13.208 V
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H12 3730
Revision: 91H12373 Serial number: 0036M0G3C2U8
Coding: 0431612
Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0301
Coding: 06022
Shop #: WSC 06335
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 981 R HW: 8E0 920 981 R
Component: KOMBI+WFS 4 H14 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0023411
Shop #: WSC 00185 210 91035
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 K HW: 8E0 035 192 K
Component: RNS-E HIGH EU H72 0500
Revision: 01S Serial number: AUZBZ7F1181401
Coding: 0309713
Shop #: WSC 02195 785 00200
2 Faults Found:
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 97
Time Indication: 0
Date: 2010.01.29
Time: 08:37:41
Freeze Frame:
Mileage: 655350 km
Count: 2901
Clock: 08:39
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 101
Time Indication: 0
Date: 2009.06.29
Time: 09:32:54
Freeze Frame:
Mileage: 655350 km
Count: 2901
Clock: 10:41
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CH
Component: Komfortgerát T3B 4135
Coding: 07151
Shop #: WSC 06335
Part No: 8E2959802E
Component: Tõrsteuer.FS BRM 0706
Part No: 8E2959801E
Component: Tõrsteuer.BF BRM 0706
Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
4 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
00955 - Key 1
35-10 - - - Intermittent
01559 - Drivers Door
60-10 - Won't Safe - Intermittent
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000005
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0309713
2 Faults Found:
02261 - Data Medium
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 97
Time Indication: 0
Date: 2010.01.29
Time: 08:37:41
Freeze Frame:
Mileage: 655350 km
Count: 2901
Clock: 08:39
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 101
Time Indication: 0
Date: 2009.06.29
Time: 09:32:54
Freeze Frame:
Mileage: 655350 km
Count: 2901
Clock: 10:41
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0022523
Shop #: WSC 02197 785 00200
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 E HW: 8E0 919 283 E
Component: Parkhilfe 8-Kan H06 0010
Revision: 00H06000 Serial number: 00067802120624
Coding: 0000114
End ---------------------------------------------------------------------
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 49554 km
Time Indication: 0
Freeze Frame:
RPM: 1470 /min
Load: 46.3 %
Speed: 20.0 km/h
Temperature: 19.0°C
Temperature: 15.0°C
Voltage: 13.081 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 50025 km
Time Indication: 0
Freeze Frame:
RPM: 780 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 29.0°C
Temperature: 11.0°C
Voltage: 13.716 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 50052 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 69.0°C
Temperature: 57.0°C
Voltage: 11.938 V
Coding: 0004533
Coding: 00000
Shop #: WSC 00000
Coding: 11021
Shop #: WSC 65536
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 49554 km
Time Indication: 0
Freeze Frame:
RPM: 1469 /min
Load: 46.6 %
Speed: 20.0 km/h
Temperature: 19.0°C
Temperature: 15.0°C
Voltage: 13.208 V
Coding: 0431612
Coding: 06022
Shop #: WSC 06335
Coding: 0023411
Coding: 0309713
2 Faults Found:
02261 - Data Medium
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 97
Time Indication: 0
Date: 2010.01.29
Time: 08:37:41
Freeze Frame:
Mileage: 655350 km
Count: 2901
Clock: 08:39
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 101
Time Indication: 0
Date: 2009.06.29
Time: 09:32:54
Freeze Frame:
Mileage: 655350 km
Count: 2901
Clock: 10:41
Coding: 00001
Shop #: WSC 00000
Coding: 07151
Shop #: WSC 06335
Part No: 8E2959802E
Part No: 8E2959801E
Part No: 8E0959801E
Part No: 8E0959802E
4 Faults Found:
35-00 - -
35-00 - -
00955 - Key 1
Coding: 0000005
Coding: 0309713
2 Faults Found:
02261 - Data Medium
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 97
Time Indication: 0
Date: 2010.01.29
Time: 08:37:41
Freeze Frame:
Mileage: 655350 km
Count: 2901
Clock: 08:39
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 101
Time Indication: 0
Date: 2009.06.29
Time: 09:32:54
Freeze Frame:
Mileage: 655350 km
Count: 2901
Clock: 10:41
Coding: 0022523
Coding: 0000114
