Testing thermostat with climate control additional function.
Posted: Sun Jan 03, 2010 10:09 am
Car: 1999 A4 2.5 TDi Quattro
My coolant temperature gauge sits below 90. I replaced the blue 4-pin sensor with a genuine Audi part but no change, therefore I suspected the thermostat. Before I replace the timing belt, etc I thought I'd check the coolant temperature using the additional functions available through the climate control display (code 51c). This shows the coolant temperature climb steadily to 90 degrees and then it stays there, doesn't even drop to 89 degrees. This leads me to suspect that either my thermostat is incredibly accurate (in which case the gauge or wiring to it is faulty), or this function doesn't display actual coolant temp. Can anyone confirm the reliability of this method?
