Major conundrum, running rough...
Posted: Wed Dec 16, 2009 10:34 pm
Ok, I have so far been tracing a misfire that originated in the LPG installation through equipment fault, the installer is currently working diligently on trying to resolve the problem, but has hit a bric wall with a phantom problem.
So far, this is what has been undertaken to trace theropt of the rough running, Which incidentally appeared at first to have cleared then materialized after about 15 miles, all on petrol! Put it on vag-com and no error codes at all... Very bizarre, especially as I know it works because it diagnosed two problems which kicked this whole episode off...
LPG system completely disconnected
All Audi wiring checked
All petrol injector inputs and outputs checked with oscilloscope and
ohmmeter waveforms all good
All coil inputs and outputs waveforms checked
Conducted cat test
Removed all spark plus and refitted after checking ok
Performed compression test all cylinders even
Performed cylinder leak down test
Checked again no error codes in Audi ECU
Replaced air flow meter
Checked for air leaks
Live data record shows closed loop fuelling and fuel trims all good
This car should run perfectly but it doesn't!! Can anyone please offer any suggestions?
Thanks in advance!
Conducted cat test
Thanks in advance!
