New VAG-COM user needs a bit of help!
Posted: Tue Jul 14, 2009 3:01 pm
Hi all, my HEX+CAN-USB lead arrived today and so far I've installed everything correctly and plugged into the car. When trying the auto scan, it gets so far (stops at different times) and then chucks out an error that is the same as if it had been unplugged.
Before you ask, I've checked both ends for security and also tried another laptop, all the same.
2ndly, so far the only code I'm getting out before failure is:
1 Fault Found:
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-10 - - - Intermittent
Readiness: 0000 0000
Can someone suggest the first thing to check please.
Thank you in advance!
Rob
1 Fault Found:
Rob
