Page 1 of 2
16985 - Internal Control Module: Memory Check Sum Error
Posted: Sat May 02, 2009 6:28 pm
by ecain63
Anyone know what this one is? Only popped up today.
P0601 - 008 - Implausible Signal
RE: 16985 - Internal Control Module: Memory Check Sum Error
Posted: Sat May 02, 2009 6:44 pm
by PetrolDave
Posted: Sat May 02, 2009 6:51 pm
by ecain63
Thanks mate. I'll reflash by disconnecting the battery and see what happens.
Posted: Sat May 02, 2009 8:08 pm
by ecain63
Sorted. Disconnected the batt and cleared all dtc's. seems to have cured the issue even after a drive. If it comes back then i'll post up again.
Eddie
Posted: Mon May 04, 2009 9:04 am
by ecain63
Well, a good bit of driving done since the reset and so far so good. No more fault codes. Must have been an oddity!
Posted: Mon May 04, 2009 9:23 pm
by grizz
Last time i had a car in with this it was down to a "iffy" remap . Removed the "iffy" remap and replaced it with a custom-code phase 1 map & all was fine .
Posted: Tue May 05, 2009 5:35 pm
by ecain63
If it pops up again mate i'll give you a buzz. Ive seen that its mainly an issue with the APR maps. how much for the CC phase 1?
Posted: Wed May 06, 2009 10:21 am
by S2tuner
If the code goes away, there's nothing to worry about, it's not down to an "iffy" remap, and MTM are definitely not people who do "iffy" remaps.
Posted: Wed May 06, 2009 2:42 pm
by ecain63
Fair point well presented.
Posted: Sun May 10, 2009 2:57 pm
by vinny
hey eddie, that "check sum error" is the ecu telling you its in need of an upgrade - preferably factory. go by the dealer and see whats involved. dont know how you guys work there, but in SA (im at the dealer) we flash the ecu with an overwrite from the factory
Posted: Sun May 10, 2009 3:34 pm
by S2tuner
Your suggestion is correct for the newer TFSI ECU's, but NOT for an RS6 vinny, sorry to correct you.
Posted: Sun May 10, 2009 6:21 pm
by ecain63
Mine has updated software anyway. But as S2 said, its not an RS6 issue.
Posted: Mon May 18, 2009 8:02 pm
by ecain63
Still no return of the DTC so im guessing that its all cured. Worth a try if you are ever confronted with the code.
Posted: Fri Jun 05, 2009 12:13 pm
by Shoppinit
How's it working now? Still no problems?
Posted: Fri Jun 05, 2009 4:39 pm
by ecain63
Still no return of the error. reckon the ecu had tripped out. How's yours?
